Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-22-2012, 08:40 AM
cycle_blue cycle_blue is offline
Eractic Speed Odometer
2001 Buick Century: My speed odometer needle fluctuates up & down which causes the transmission to up shift or down shift. Is this a speed odometer problem or a trans problem?
Old 04-22-2012, 08:51 AM
Re: Eractic Speed Odometer
Another detail to my problem: the speed odometer is sometimes stablbe. When it is the transmission does fine.
Old 04-23-2012, 08:14 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Welcome to AF!!
The speedometer is electronic and works off the speed sensor in the transmission. The computer relies on the speed sensor to shift the transmission and if it is eratic the trans will not shift normally. Replace the speed sensor and the problem should go away.
Old 04-23-2012, 10:59 AM
Tech II Tech II is offline
I agree with GTP Dad, but just for ha-ha's, check the harness to it, and the integrity of the connectors at the harness connector....
Old 04-23-2012, 03:46 PM
Thank you so much! As you can see, I am a newbie to the forum and it is worth every minute of it.
I am an amatuer mechanic but very mechanically incline. I suspected the VSS but wasn't truly sure how it, the trans and speedodometer all tied together...which hand shook which and in what order. I was told by a GM mechanic that he suspected the cluster panel but now I will head for the sensor.
Thanks again and I'll let you know how it turns out.
Old 04-26-2012, 04:27 AM
Scrapper Scrapper is offline
AF Premium User
i'll put my money on speed sensor replace sensor and you should be fine..but how longs this been doing this?
good luck..
Old 04-26-2012, 09:06 AM
We just inherited the car from my elderly inlaw. Not sure how long it's been like this. I did replace the VSS from a parts car that didn't have this problem. When I drove it up and down the street it seemed to still be doing it a little...I guess I need to get it out on the highway to know for sure. I did notice hard shifting when I test drove it but on the test drive I didn't get over 30 mph. I was going to flush the tranny, new filter and fluid to see if this helps. The fluid is brown and had tiny bubbles in it.
How can I check the wiring going to the sensor? Or can it be checked? Maybe the signal is not getting back to the PCM.
I did do a visual inspection of the wiring harness at the sensor and it appeared fine.
Old 04-27-2012, 07:56 AM
Pontiac Guy
Changing the fluid and filter is a good idea especially if the fluid is brown. When you change the fluid add a can of Seafoam transmission additive to it. This will remove any gum or deposits an help the transmission to shift better. If you still have the problem after that you may want to take it to a transmission shop and have them diagnose the transmission issue for you. It is generally free to diagnose a problem.
The Following User Says Thank You to GTP Dad For This Useful Post:
cycle_blue (04-27-2012)
Old 04-27-2012, 09:48 AM
Thanks GTP Dad! I'm performing the fluid/filter change today. I'll try the Seafoam and see where that takes me.
Transducer/Odometer carlosdesa Engineering/ Technical 8 10-31-2011 08:58 AM
95 TC Odd Digital odometer issue tenths pjw73nh Town Car 4 02-26-2010 10:34 AM
1991 GM Speedometer, tripometer, odometer and cruise quit working. Janett_vh Grand Marquis 3 05-04-2009 12:36 AM
2004 Trailblazer Speed Odometer Stuck azradrods99 TrailBlazer | Trailblazer EXT 2 05-22-2006 05:22 PM
Question about 89 Speed Odometer S and S M Bodies 2 04-23-2004 10:47 PM
