Old 04-21-2012, 02:55 AM
saturnthegiant saturnthegiant is offline
How to do a compression test?
Wondered if anyone could tell me the steps to do a compression test on a '99 Jimmy? With a screw in type gauge.... do you have to disable the fuel pump, etc. I need to determine if the head gasket is blown. Thanks.
Old 04-21-2012, 08:35 AM
goser goser is offline
Re: How to do a compression test?
http://www.automotiveforums.com/vbul...d.php?t=954856
'01 Chevy Blazer ZR2 4x4 VIN=W
'80 Yamaha XJ650 Maxim
'08 Jeep Patriot 2.4L
Old 04-21-2012, 09:28 AM
tempfixit tempfixit is offline
Here is a video that shows a quick way to test for blown head gasket wih a compressor.
http://realfixesrealfast.com/realfix...nder_Head.html
Old 04-21-2012, 09:54 AM
old_master's Avatar
Advisor/Moderator
What are the symptoms that you're experiencing? Keep in mind that the 4.3L engine has very few head gasket failures. Most of the time when they are replaced, it's due to a misdiagnosis. Lower intake manifold gaskets are a very common failure.
Remove all of the spark plugs, prop the throttle open, install the gauge and crank the engine over until you hear/feel 4 compression strokes. Do this for each cylinder and write down the results and label them as "dry". The test results should not vary more than 10% from the highest to lowest cylinder. Then squirt about a tablespoon of oil in each spark plug hole and check compression again on all cylinders labeling this test "wet". The wet results will be higher, but should not vary more than 10% from highest to lowest cylinder. The wet test helps the rings seal and if the compression spikes higher on a particular cylinder, one or both compression rings are cracked/broken.
You have to know how it works,
to figure out why it doesn't.
Old 05-02-2012, 10:04 PM
Well, turns out the head gasket is blown, as i suspected. I'm having it repaired as we speak. Thanks for the help, guys!
Old 05-06-2012, 09:26 PM
phillipshaw phillipshaw is offline
Ive been expereincing it too. and it was so difficult for me to fix it, that's is why I ask some help to experts.
“In three words I can sum up everything I've learned about life: it goes on.”
― Robert Frost
Need help with Compression Test and Boost Leak Test AbsoluteGTR Eclipse Problem Diagnosis 4 07-16-2006 01:39 AM
How much does a compression test run? Spectre120 Camaro Discussions 1 09-06-2004 11:08 AM
compression test redmanjd Integra 6 11-18-2002 05:31 AM
So I redid the compression test the RIGHT way... habib_88 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-09-2002 04:03 PM
Did a compression test tonight, how'd my car do? habib_88 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 06-01-2002 01:19 PM
