Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-18-2012, 10:02 AM
griz763 griz763 is offline
fuel pump pressure
I have my fuel pump isolated pumping to fuel pressure gage only it pump to about 70it psi and then starts dropping should it hold pressure or is that normal for it to bleed down it has a new delphi pump i kept the old pulsator in there could that be leaking by
Old 04-18-2012, 01:17 PM
NHRA's Avatar
NHRA NHRA is offline
Re: fuel pump pressure
you need to test it after the regulator and should hold presure
The Following User Says Thank You to NHRA For This Useful Post:
griz763 (04-18-2012)
Old 04-18-2012, 04:01 PM
Oh I know that to test regulator but when I put my new pump in I installed the old pulsator that sits on top of fuel pump and was reading on here thar I with couldve done away with it and once I do does the pump have its own check valve to hold pressure if you isolate the pump
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
fuel pump pressure specfications dieter LeSabre 7 07-29-2009 02:05 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
