Old 04-16-2012, 03:20 PM
bigtrout bigtrout is offline
new ignition switch w/ accessory position for a 66'
I want new ignition switch that has an accessory position, wondering if anyone has done this? I was thinking maybe an early impala switch might work
Old 04-17-2012, 01:38 PM
Schurkey Schurkey is offline
Re: new ignition switch w/ accessory position for a 66'
The one you have now doesn't have an accessory position?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-18-2012, 11:59 AM
No, it does not. it only has off, on, & start position. think because it's a truck
Old 04-18-2012, 03:30 PM
I learn something every day. I'd have expected it to be like the cars--put the key in, push, turn counter-clockwise past the spring-loaded detent.
First Guess: You'll have to add wires to the harness to get a functional accessory position even if you add a different switch.
Old 04-18-2012, 03:46 PM
j cAT j cAT is offline
why do you need acc. position ? whats needed to operate with engine off ? If this is a radio/amp, hook up to the battery feed . fuse at the source. then use this to supply power directly to the devices or to a switch that can be turned on /off .
just make sure you use #12 wire or larger , so that the wire can handle the amps required. low voltage requires bigger wire.
