Old 06-03-2003, 08:53 AM
doug294 doug294 is offline
Send a message via AIM to doug294
keep B18 powersteering?
Ok another question about the B18. The B18 is powersteering and my 91 Civic is not. So what do I do about this? Also doesn't the integra have rear disc brakes? So could I use these?
Old 06-03-2003, 01:08 PM
91civicDXdude's Avatar
yes you can keep the power steering, but you'd have to switch the whole rack. i *think* it will work, as long as the tie rod ends match up, since you have to keep your stock spindle.
as far as the rear discs go, swap em. all you need is the rear trailing arm & brake assembly, the other arms wont work. its a simple swap. you dont *have* to use a bigger master cylinder, or change your brake proportioning valve, but its recommended. BTW, if you choose to use the integra master cylinder, you'll have to swap over the brake booster as well becuse the master cylinders on tegs have the bolts on reverse side of civics.
good luck.
Powersteering SIKCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 19 09-08-2003 09:18 AM
JDM b18 or gsr b18 ndekens Engineering/ Technical 3 05-08-2003 03:41 PM
TO B18 or not to B18 Kunundrum '88 - '91 Civic | CRX | Wagon | Shuttlee 7 03-23-2003 11:24 PM
how hard is it to move the powersteering pump when doin sr20 swap???? HELP sk8terCraig 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 08-25-2002 02:16 PM
