Rainy Day Problem-93 Mercury Villager
On rainy days, my Villagers begins to miss, as though it is starved for fuel, or maybe air. Anybody have any ideas?
Re: Rainy Day Problem-93 Mercury Villager
When was the last tune up??? cap, rotor, plugs and wires. |
| The Following User Says Thank You to tempfixit For This Useful Post: | ||
Edward L (04-14-2012)
Thanks for the reply. Edward L |
You may want to also check the wires to the injectors to make sure they are tight and possibly add some di-electrical grease to them to see if that helps.
Does the gas mileage seem to change when raining. When you replaced plug wires did you apply di-elctricall grease to both ends of wires to prevent moisture from causing problems?? Try the water spraying trick to help diagnose. Last edited by tempfixit; 04-14-2012 at 08:36 PM. Reason: wordage |
I have a '97 and a '95 villager and both are very fussy about the distributor cap. Once the cap was replaced the wet day missing stopped. After close examination in sunlight I found a tiny carbon trail inside the cap causing the missfire.
| The Following User Says Thank You to Animal48197 For This Useful Post: | ||
Edward L (04-19-2012)
Hey Thanks. This is something I'll try shortly.
