Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-13-2012, 09:48 PM
leduc14 leduc14 is offline
2000 Bonnevile SSEI
Hello
I have a 2000 ssei Bonneville. The issue that I’m having is my car hesitates when I accelerate. It feels choppy. I have replaced all coils and plug wires. I have also replaced the mass air flow sensor. I was wondering if someone could lead me in the right direction so that I could fix this issue. Thanks
Old 04-14-2012, 08:25 AM
Tech II Tech II is offline
Re: 2000 Bonnevile SSEI
"Choppy"? Not sure of that description......could be a slipping tranny, a misfire, cv joints, etc.
Let's say you are cruising at 50mph on a highway, and are going up a slight grade.....if you LIGHTLY accelerate, do you feel a misfire?
Does your CE light flash? Have you checked for engine and transmission codes? Have you checked coil output? Checked condition and level of transmission fluid? Replaced plug wires and coils, did you replace plugs too? Use OEM?
Old 04-14-2012, 08:32 PM
Hello again.
Thanks for your reply. Yes sometimes I feel a misfire when I accelerate. In the past I received an engine codes which was a cylinder 1 misfire. I replaced a coil and it went away. Now over 1 year later I have similar issues. I have no engine or transmission codes. So that is the reason why I purchased new coils, plug wires and fuel filter. I also just replaced the tranny fluid and filter. I guess I haven’t changed the plugs yet. After I change the plugs and if it doesn’t go away what else could it be? Are there any sensors that could need replaced?
Old 04-14-2012, 09:21 PM
Let's try the plugs first(use A-C/Delco), and make sure the wires are going to the correct cylinders....
Old 04-19-2012, 11:40 PM
Hello again.
Just changed the plugs. Used AC delco. Car still has issues when i accelerate. Some days better than others. Somedays i don't feel it at all. Was wondering what else it could be?
Old 04-20-2012, 05:39 PM
Any corrosion at the coil terminals? Check coil output with a spark tester?
Old 04-20-2012, 05:50 PM
I don't notice any corrosion. It all looks good.
2000 Bonneville SSEI Steering VITHALRAKESH Bonneville 1 03-17-2006 07:55 PM
2000 Bonneville SSEI Performance? 2000blazerls Bonneville 2 02-08-2006 09:20 PM
2000 Bonneville SSEI SC Exhaust 2000blazerls Bonneville 0 09-11-2005 07:31 PM
2000 Bonneville SSEI Transmission problem BonnevilleSSEI Bonneville 1 10-31-2004 09:35 AM
FS: 2000 Bonneville SSEI- Loaded SADJ Bonneville 0 12-01-2003 03:54 PM
