Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-11-2012, 05:12 PM
luis24708 luis24708 is offline
Unhappy 1996 neon need help fast having problems installing trasnmission
i have a 1996 dodge neon automatic trans i have just began installing a diffrent trans but i can not seem to get the torque converter bolt holes to align with the fly wheel bolts i cant finish installing if i cant correct this anybody have an idea of what am i doing wrong plzs help thanks
Old 04-25-2012, 06:07 PM
Oldsmobile Doctor Oldsmobile Doctor is offline
Re: 1996 neon need help fast having problems installing trasnmission
Due to the timing marks being on the torque converter the bolt holes are not symmetric meaning one hole is offset. The converter will only go on one way it is best to mark one of the flywheel holes and the matching converter hole. If you didn't do that you have to install one bolt almost all the way in but still loose and turn the engine over to check the other three. If any of them don't line up take then out and move the converter one hole and start over. It is possible that you would need to do that 3 times before it matches up. At least a neon engine is easy to turn over by hand unlike a 440
1996 neon rough everything jtorsey Neon | Plymouth Neon 2 02-24-2009 09:17 PM
Need Help Fast Coil Problem! mas&NKS Performance 2 12-05-2006 02:20 PM
Daily driver Down. need help fast. tranny problems animalgonz666 General Discussion 5 11-01-2005 10:25 PM
I HaVE A PRoBLeM!!!!! NeeD HeLP FaST!!!zC motoR kutlass '88 - '91 Civic | CRX | Wagon | Shuttlee 8 06-23-2004 10:53 AM
