Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-09-2012, 09:08 PM
02LincolnTownCar 02LincolnTownCar is offline
Gas Mileage Is Too Low On Town Car
I recently purchased a 2002 Lincoln Town Car with 204,000 miles but it runs like a champ. The Problem Is It burns too much gas i filled the tank up and2 days later i'm at a 1/4 tank without driving very much. My fuel economy states that i'm getting 8.5 miles a gallon this number goes up and down. I changed the oil and air filter still having the same problem. I need to know what I can Do to fix this I have heard the plugs and possibly the coils but I would like to know if there is more or perhaps something else I will be doing the work mostly myself but i do have an uncle who is good with cars and will help me, any answers or suggestions will be greatly appreciated.
Old 04-09-2012, 09:25 PM
FishFind FishFind is offline
One Hot Shot
Re: Gas Mileage Is Too Low On Town Car
any codes??
Old 04-09-2012, 09:31 PM
no codes or lights showing anything wrong
Old 04-10-2012, 10:46 AM
All2kool's Avatar
All2kool All2kool is offline
How you drive these cars will make or break your MPG. The next time you are out cruising, try this: When you see the stop sign or traffic light ahead if you, take your foot off the gas and coast the last 1/4 to 1/2 mile. Believe it or not, these 4100lb. cars can coast for miles without losing much forward inertia. I average 22 MPG city and up to 29.8 MPG highway easily.
Old 04-10-2012, 11:07 AM
skinnywhitekid skinnywhitekid is offline
Cool Re: Gas Mileage Is Too Low On Town Car
A car this new should not have to practice coasting to stop signs. You should be getting the mpg's no matter what with something that new. The older ones do make a huge difference on how you drive them. I would have a full tune up done on it. something with that many miles will be little worse too.
just do a basic tune up and see what happens
basic tune up video how to DIY
The Following User Says Thank You to skinnywhitekid For This Useful Post:
02LincolnTownCar (04-10-2012)
Old 04-10-2012, 11:15 AM
All2kool's Avatar
I beg to differ. If you're driving like a bat of hell, your MPG will reflect this. If your foot tends to go directly from the accelerator to the brake pedal, you need to change your driving habits. If you're the first car 'off the line' at red lights, change the way you drive. My 1996 Cartier with 160,000 miles is getting 29.8 MPG on the highway at 60 MPH and your car should get the same or better. I average 23 MPG city because of THE WAY I DRIVE. The Spark Plugs in my car have seen 40k miles. I'm thinking I'll change them soon but when you're getting almost 30 MPG in a Lincoln Town Car, why bother?
Check your tire pressure - tires not properly inflated can rob you of MPG.
And finally - when you're pressing the accelerator, you're using gas. If you can coast that 1/4 mile, you can save gas. You don't need to be a rocket scientist to see what I'm saying.
Old 04-10-2012, 08:58 PM
Thanks for the input I'm going to try that I was just hoping some one had a similar situation and fix
Old 04-10-2012, 09:01 PM
I see what you are saying but even If i'm driving like a bat out of hell the instrument panel shouldn't tell me i'm getting 5, 6, or 8 miles a gallon but thanks for the input
Old 04-12-2012, 05:40 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I agree with All2kool, if you drive like there is no tomorrow, even a 4 cyl. will have low fuel economy.
Having said that, you could try cleaning your MAF sensor too. Use only MAF cleaner or electric contact cleaner available at most autoparts stores. Take a look at it under a magnifying glass and you should be able to see some dirty on it...
Perhaps even a vacuum leak... Make sure all the hoses running to the throttle body are OK. If you have a live data capable scanner you can take a look at the LTFT's to make sure if you PCM is adding too much fuel or if something is out of the normal.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
The Following User Says Thank You to olopezm For This Useful Post:
02LincolnTownCar (04-12-2012)
Old 04-12-2012, 09:01 PM
Oscar.
Yeah i see what both of you were saying, but i'm not getting a chance to drive fast or far because the gas is burning out too fast. tomorrow i'm supposed to change the plugs and possibly the fuel filter i'll post after and let you all know what happened. since i changed the oil air filter and flushed the radiator it seems to be holding steady at 8.5 miles a gallon but that's still not normal, wish me luck tomorrow and thanks for all the input and suggestions.
Old 04-12-2012, 10:00 PM
All2kool's Avatar
When you changed the Air Filter - did you reattach the Sensor to the side of the Air Box? It can easily come off and go unnoticed.
The Following User Says Thank You to All2kool For This Useful Post:
Old 04-12-2012, 10:08 PM
I didn't even notice one on there, i'll have to check in the morning. what side is it on the driver or the passenger? or is it front or rear?
Old 04-12-2012, 10:39 PM
All2kool's Avatar
Rear, as I recall. Small Sensor, half-turn or so locks it in place.
Old 04-12-2012, 10:40 PM
All2kool's Avatar
Rear, as I recall. Small Sensor, half-turn or so locks it in place. It may not be present on an '02 LTC but it is on my '96.
Old 04-13-2012, 04:05 PM
olopezm's Avatar
Are you talking about the IAT (Intake Air Temperature) sensor?
I think it was removed from the airbox to be relocated into the MAF sensor itself. That's why some newer models have a 6 pin MAF sensor.
Oscar.
Starting problem, decreased gas mileage on 97 suburban mlhempton Suburban 0 05-10-2011 03:39 AM
Better gas mileage Stapletonb08 Cavalier 3 03-03-2011 01:02 PM
City gas mileage too low. LYLY Caravan | Voyager 2 02-08-2010 12:00 PM
Tags
2002 , car , gas , mileage , town
