Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-08-2012, 10:13 AM
phynix21 phynix21 is offline
98 Eclipse GS MAF, MAP, intake air temp issue
ok so long story short, after car warms up it sputters then dies. obtained codes from check engine light, MAF, Intake air temp, and MAP all are malfunctioning. when i unplug the MAF while engine is running it eliminates the sputtering and car idle is smooth again. Which part should i change first? i found a MAF fromaround $50, which is real cheap. i havent priced the rest yet but i wanted to ask which part would be better to change first on a tight budget like mine. im assuming the MAF since unplugging it allows me to drive it without it killing. any help would be great, thanks
Old 04-08-2012, 10:52 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 98 Eclipse GS MAF, MAP, intake air temp issue
Can you give us the exact codes that are being thrown by the CEL?
The GS model DOES NOT have a MAF sensor. Are you sure this isint the turbo model? The non turbo model uses speed density to calculate fuel which only needs a MAP sensor. Im not sure which sensor you are calling the MAF but we do not have one on the 420a.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-08-2012, 04:27 PM
sorry its a 1998 eclipse spyder non-turbo, and as far as i can tell from all the research i have done there is a MAF located on the air intake right after the air filter.
the three codes i get are: p0110, p0100, p0105
Old 04-09-2012, 06:34 AM
Holset powered 420a
Ok that makes more sense, the spyder does have a MAF sensor. All three of those codes are related to the MAF as well. The chance of all three of those sensors going out at the same time is not very likely. You might want to start looking at other options. I would first make sure that it is plugged in all the way. Swapping in a different MAF would be a good idea to either eliminate that possibility or solve the problem. Then start looking into the wiring if that doesn’t fix the problem.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-10-2012, 07:04 PM
Forgot to mention the cause of the issue, or at least what I think caused it. I crossed the positive and negative cables when jumping the car. After that is when the problem started.
Old 04-11-2012, 07:04 AM
Holset powered 420a
Well that doesnt make any this any easier.. I would start testing to see if you are getting power to the MAF plug. At this point I would try replacing the MAF and if that doesnt fix it maybe the ECU.
98 Eclipse GS Turbo
2001 BMW 325i - DD
need help with intake air temp sensor mvb1212 Celica 2 05-12-2005 02:09 PM
Intake air temp sensor. SMarquez Camry/Camry Hybrid/Vista 4 02-08-2005 05:08 PM
1992 eagle/mitsubishi mirage intake air temp sensor? punxnotdead Mirage 4 10-27-2004 02:56 PM
Wheres my Intake Air Temp Sensor ? justaguy07 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-27-2004 11:05 PM
Intake Air Temp Sensor... 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 04-27-2004 05:39 PM
