Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 04-06-2012, 05:28 PM
luvmyS10's Avatar
luvmyS10 luvmyS10 is offline
A diy guy...if possible
What type ac compressor do I have on my truck
I have a 03 Sonoma 4x4 crew cab with 4.3. The ac works fine but as I pulled into the drive way I heard a strange sound. After checking it was the ac compressor. when i turn on the ac the compressor sounds like its clacking or knocking. It gets louder with higher rpms. I was going to replace the compressor and dont know if its a H6 or a HT6. any ideas or suggestions would be helpful. Thanks
2003 GMC Sonoma crewcab 4wd
Old 04-06-2012, 09:14 PM
old_master's Avatar
Advisor/Moderator
Re: What type ac compressor do I have on my truck
4.3L V6 engine uses a Harrison HT6. The 2.2L 4 cyl engines use H6. Very common, (as in they all do it) for them to develop a leak where the case halves come together. Usually on the bottom where you can't see it without removing it. Sanden makes a different design compressor and doesn't have this problem, and it's much quieter than the Harrison.
Harrison HT6 compressor:
Sanden compressor:
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
luvmyS10 (04-10-2012)
Old 04-07-2012, 02:00 PM
luvmyS10's Avatar
Thank you! the part store here has everco and uac brands available without ordering, do these work well? or should I wait and order online thanks
Old 04-07-2012, 04:04 PM
old_master's Avatar
Advisor/Moderator
I've replaced countless compressors, but never a Sanden. I've been installing them for several years and haven't had a problem. It's a mechanical part and eventually they will fail too, but, the design is superior to the H6 and it's noticeably quieter. If you get a remanufactured compressor, you're at the mercy of the rebuilder, might get a good one, might not. I stay away from reman compressors. Everco has been around for years, and generally has good quality parts, not sure who makes their compressors though. uac... never heard of them. Hope this helps.
Old 04-10-2012, 06:04 PM
luvmyS10's Avatar
Thank you, but I mistated the brand, not uac but compressorworks. But I went and checked out sanden website, out of stock...my luck..lol. All I priced was new, no rebuilt for me. But thank you for the info
Old 07-08-2013, 02:56 PM
Fixxer1963 Fixxer1963 is offline
Hi.
I am also trying to find out what type compressor I have in my truck.
97 Chevy 3500 diesel. I need to know what type so I can buy a rebuild kit for it.
It still works, but leaks from the big seals on the end. I used to rebuild transmissions, so I think I can handle this. If not, I will only be out the money for the kit.
Old 07-08-2013, 09:36 PM
old_master's Avatar
Advisor/Moderator
Originally Posted by Fixxer1963 View Post
Hi.
I am trying to find out what type compressor I have in my 97 Chevy 3500 diesel.
Yours originally came with a Harrison HT6, (the top one in post #2).
Fixxer1963 (07-08-2013)
Old 07-08-2013, 09:47 PM
Thank you for the info, that is what mine looks like. I just wanted to be sure.
Old 07-08-2013, 09:51 PM
old_master's Avatar
Advisor/Moderator
Pay extra attention to the case seal, oil it up good when installing it. When you reinstall the compressor, tighten the bolts in a criss cross pattern and torque them to spec. If you don't, the case seal will leak prematurely.... again.
Old 07-08-2013, 09:55 PM
brcidd's Avatar
brcidd brcidd is offline
Uhm-- S-trucks with 4 cylinder engines used a V-7 compressor from 1997 till the end....not an H6
Just sayin''
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Old 07-08-2013, 10:26 PM
old_master's Avatar
Advisor/Moderator
Just sayin''
Good catch, yup, you're right!
Old 07-08-2013, 10:30 PM
I have been reading a lot of stuff about the HT6 being a bad design.
Is it possible to replace it with the Sanden without changing anything else?
Like, will the existing hoses and wires fit the Sanden?
Old 07-09-2013, 07:33 AM
brcidd's Avatar
Yes , yes it is a drop in....
'99 GMC Yukon
Fixxer1963 (07-09-2013)
Old 07-09-2013, 11:00 AM
Thank you. That sounds like the best route to take.
Old 07-10-2013, 09:20 PM
I looked on Sanden.com's site and found that it was a model 4440. In case anybody in the future reads this thread, and needs to know.
what type of performance does the944 have? ryanisfast 924/944/968 69 08-28-2005 06:34 AM
What type of car do you have? TorinoGT69 Engineering/ Technical 47 10-17-2004 10:46 PM
what type of muffler do you have?? frostee '88 - '91 Civic | CRX | Wagon | Shuttlee 26 12-30-2003 01:09 PM
what type of engine do i have 4dr91ex '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-16-2002 03:40 PM
What types of fragrances do you have? S Brake COMPLETELY off-topic 28 03-28-2002 02:38 PM
