Old 04-05-2012, 08:54 PM
Amopower Amopower is offline
Send a message via AIM to Amopower
compatibles with 1993 Lesabre
I might be looking for another Lesabre body if I cannot get my undercarriage rust issues fixed. Everything else on my car is great, so I'd probably swap just about everything from mine to the donor shell. My question is, what year(s) should I limit my search to? I would prefer not going so deep with the swap that I also need to swap out the computer. Does anyone know which car years/models I would be limited to? I am pretty sure I am limited to a 1992-1993, but not totally sure about 1992. (also - this is a Limited, and I am not sure if the computers are even different for that vs Custom)
thanks
Old 04-05-2012, 10:17 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: compatibles with 1993 Lesabre
thanks
Try car-parts.com and fish for the parts you'd consider switching to see which other years are compatible with your 93 leSabre.
Old 04-05-2012, 11:54 PM
I'm basically looking for year(s) where the computers are compatible, that's my bottom line.
Old 04-16-2012, 10:02 PM
spinne1 spinne1 is offline
The shell was basically the same from 92-94. The engine in 92 is different than 93-94 (tranny changed after 92 or 93 as well.) Even the 95's shared most everything body wise with 92-94. The changes then were interior trim a bit, steering wheel, radio, airbag on passenger side (or was that 96?), and maybe other minor details. Best to get your exact year to ensure complete compatibility (and same trim and level of trim would also help).
Old 04-16-2012, 10:07 PM
Actually the 94's introduced the 4 spoke steering wheel and the passenger airbag...so yeah I'm thinking 94 and up is out of the question. So I'm back to my original guess that I might be limited to 92-93, and perhaps only 93. For the trim, I probably don't want to deal with those side moldings either, so I might as well "limit" my search to a Limited. (i've tried removing some of these at a pick and pull, and they just don't want to budge. Not sure how the body shops deal with them).
question about 1993 lesabre jessitrzeb LeSabre 7 04-03-2010 02:49 AM
error or trouble codes 93 buick lesabre custom thecone_99 LeSabre 9 03-03-2009 07:49 AM
1993 lesabre, shuts off & smoking!!!!!! Help! swhite914 LeSabre 6 11-05-2004 12:26 PM
1993 Lesabre stuck in panic mode???? Ralph241 LeSabre 5 09-22-2004 08:12 PM
1993 Lesabre Buildout BadA--Buick LeSabre 2 06-07-2004 11:02 PM
