Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 04-05-2012, 07:33 PM
Sizzlinninja Sizzlinninja is offline
Turn signal wires, would this work?
Okay so I got some new aftermarket headlights today. Basically, this was suppose to be a plug and play type deal, and it was until I got to the blinkers. The stock male end does not fit the female aftermarket end. The stock one as three wires: red, green, and black. The aftermarket has blue and black. So I researched this, and turns out on the stock end, the red wire is for the blinkers, the green wire is for the running lights (this makes the turn-signal bulbs come on at night and glow, but not blink), and the black is ground. So basically if I cut the stock male end off, and put the red and green wires in a female rod connector and crimped them, and attached them directly to the positive rod on the other female end, and then attached the ground to of course the ground. Would that work? The only flaw I see is that it seems that the blinkers might not work at night.. If they are already on by the running lights, and I flipped the blinker switch, it doesn't seem like they would blink if they were already on.. What do you guys think?
Jeep 2000 GCL, turn signals work intermittently, hazards work fine mgtyjoe Cherokee 1 06-15-2008 01:25 PM
Turn signal turns off/won't work 2001 Passat Luism12lm '97+ 1 07-15-2007 09:40 PM
turn signal wiring problem on 92 hatch prototype80 Exterior | bodykits | Lighting 0 10-29-2004 07:10 PM
Turn Signal Wiring Problem twitchie Cherokee 2 07-12-2004 07:27 PM
1994 Chevrolet G20 Van brake/turn signal wiring problem Kindred Wolf General Discussion 0 09-01-2003 11:47 PM
