Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 04-04-2012, 11:40 AM
SusanM40 SusanM40 is offline
2003 Fan issues - I am clueless. Please help!
Hi. The engine fan in my 2003 MC SS doesn't seem to be working and the car is starting to overheat. The other fan, which I think is the A/C fan seems to be working okay. I know nothing about cars and before I take this to a mechanic, could someone tell me what might be the issue...I do not want to go somewhere and get totally ripped off. So it would be nice if I appear to know what I am talking about... when i take it to the mechanic.
Thanks a million for any help,
Susan
Old 04-04-2012, 12:26 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2003 Fan issues - I am clueless. Please help!
If indeed you have a cooling fan problem, and it is with primary cooling fan, you could have a blown fuse, a bad fan relay, a bad fan motor, broken wire or a PCM problem or a temp switch.
Old 04-04-2012, 09:52 PM
Tech II Tech II is offline
If the fan runs with the A/C on, it seems that the fan should be ok......we would need a schematic of your fans.....systems are different for different cars......there are low speed and high speed setups....on some, just the low speed fan comes on....if it alone can't lower the temp, then the second fan comes on also.......other systems, via relays, both fans are wired in series and run together at low speed.....if high speed is called for, then relays switch and the fans are wired in parallel, and spin faster.....
How high is the temp going on the gage? I don't think the fan runs until the temp reaches 220F......how is the coolant level?
325 Ci 2003 A/C prob, please help!!! sal5pointo 3 Series 4 08-22-2010 11:10 AM
HID Issue ( Please Help ) Tiburon11725 Tiburon | Tuscani 1 05-26-2010 02:08 PM
2003 Sable transmission problem please help! 03Merc Sable 6 12-17-2007 06:19 PM
renault clio 11 overheating, fan not spinning, please help ugy101 Clio/Clio II/Clio III 2 07-15-2007 07:29 PM
Corsica Radiator Fan Not Working....PLEASE HELP!! Oli_Oli_Umphry Corsica 8 06-05-2006 07:01 PM
