Old 04-04-2012, 10:22 AM
Timtickle Timtickle is offline
2005 Trailblazer "low collant temp" Light
I have been battling this for some time. The check engine light comes after a period of time from reset. I have changed the thermostate, temp sensor, coolant flush and added per MFG.
I am down to clutch fan. ANY F'n ideas people? The temp guage sits right at 210.
From what I can tell is the check engine light comes on because the engine reaches operating temp to SLOWLY. Im guessing because the clutch fan is spinning to early in the game. Please help.
Old 04-04-2012, 11:21 AM
maxwedge maxwedge is offline
A990 racer
Re: 2005 Trailblazer "low collant temp" Light
First of all what is the code?
Old 04-20-2012, 10:47 AM
It is "low collant temp" P0128
Definition
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
Old 04-20-2012, 12:35 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Usually a t-stat takes care of the P0128. Are you sure you used the correct temp stat when you replaced it? If so, you may have a fan clutch issue, it would be a little unsual though.
Old 04-21-2012, 12:13 PM
Schurkey Schurkey is offline
I thought there was a considerable history with defective fan clutches that would lock up and not release.
The usual complaint is lots of fan noise.
Hayden--and probably others--make an upgraded fan clutch for this application. The Hayden number is 3201.
http://www.amazon.com/Hayden-Automot...5028368&sr=8-1
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-21-2012, 07:47 PM
gmtech1's Avatar
Yes, there is a problem with the fan clutches staying engaged,like you said, you would hear it if it was. I was just saying the the fan clutch usually does not cause p0128. If you suspect a fan clutch, by all means replace it.
"Low Coolant Level" Light gtpguy Grand Prix 8 07-12-2009 06:19 PM
"low wiper fluid light always ON!" 1989xjlimited Cherokee 5 11-27-2005 10:07 AM
96 Buick Regal Custom "low trac" warning light whbonney Regal 7 07-22-2005 12:19 PM
95 Old Achieve "Low Coolant level" light Haole101863 General Discussion 1 01-22-2005 05:12 PM
2005 trailblazer boothe7373 TrailBlazer | Trailblazer EXT 0 09-12-2004 10:08 AM
