Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-03-2012, 08:12 PM
ziggy1969 ziggy1969 is offline
Question Major External Coolant Leak (only at operating temp)
2003 Pontiac Montana 3.4 L
225000 Kms
Intake Gasket replaced allready at 60,000 kms (yes a while ago)
Recently, noticed a major external coolant leak at the front of the motor (passenger side). It only leaks when at operating temperature and under pressure. It does not leak when you first start the engine, it takes a while before it leaks.
I replaced the rad cap, just in case it was faulty. Upon the second test, after getting it running good and hot, it leaked again. But only when at operating temp. It is not overheating.
Problem is, as the coolant is leaking out, the main drive belt is spashing the coolant all over the place and thus I am having a heck of a time pinpointing if it is a head gasket or intake manifold leak or perhaps somewhere else.
I can't take things apart to get a better view, because it needs to be running at operating temp to get the leak. If I pull anything apart for a better view, I won't be able to start the engine to reproduce the leak.
Any tricks or suggestions would be greatly appreciated.
tia
Zig
Old 04-03-2012, 09:39 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Major External Coolant Leak (only at operating temp)
I would suggest buying/renting a pressure tester for the cooling system. This will let you pressurize the system without it running. Then inspect LIM and water pump. You can pull the belt off and remove the pump pully for closer inspection of the water pump weep hole. Good luck!
Old 04-18-2012, 01:05 PM
truc0011 truc0011 is offline
Mine did this on the right side (near firewall), it was a bad headgasket!
Old 04-18-2012, 04:18 PM
Tech II Tech II is offline
If the belt is throwing fluid, like Gmtech1 said, I would look at the w/p first.....
Old 10-28-2012, 10:54 AM
thanks everyone for your help and advise. I did borrow a pressure tester and it turned out to be the water pump.
Good News, changing the water pump on the Montana 3.4L was not to difficult
Zig
The Following User Says Thank You to ziggy1969 For This Useful Post:
danielsatur (10-28-2012)
Head gasket, external Coolant leak? suburbanstevie Intrigue 3 12-05-2010 01:07 PM
Strange external coolant leak venturenot Venture 14 12-28-2009 11:05 AM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
windstar 96 extensive external coolant leak mikemf Windstar 6 09-30-2005 03:11 PM
External Coolant leak gdawg415 Blazer 2 05-29-2004 10:18 PM
