Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-02-2012, 06:59 PM
bigryry bigryry is offline
Starting Problem
I have a 2002 Explorer 4 door with the flex fuel V6 engine with 157k miles. This has happened twice in a month. You got to start the truck and it starts to crank for a second and half and then it completely stops for a half second and then starts cranking again and fires up. The kicker is after it did this the instrument guages, all of them, stayed at nothing when it started and then they all at the same time went to the highest level and then they all dropped back down to nothing and then rose to their perspective postions. My trip gauge reeset it self to zero as well.. ANy ideas?
Old 04-02-2012, 07:45 PM
FishFind FishFind is offline
One Hot Shot
Re: Starting Problem
Ignition switch, Ignition fuse, power feed to ignition.
Old 04-03-2012, 06:38 AM
I was thinking that but what concerns me is the gauges acting weird and the trip resetting to zero..
That is all stored in the computer?? I worried it is something more with a control module or the computer.
Old 04-03-2012, 12:15 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
If I recall correctly, the trip meter will reset to zero when the diagnostic codes are cleared or the battery is disconnected. I'd start my search by checking the condition of the battery cables and connections to make sure they are secure and clean. If the battery cable ends are the type where the stripped cable is tightened down to the clamp, I'd suggest you purchase a set of molded cables and replace the temporary cables.
-Rod
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 05:56 PM
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 04:04 AM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
