Old 03-29-2012, 12:22 PM
blk95lumina blk95lumina is offline
Water leaking into cab - passenger side front only
Hello.
I have a 2000 RCSB silverado 1500. Pics of the issue attached below.
I have noticed water leaking into my cab after a huge rain like we have recently experienced in Texas. Water also leaks when I wash my truck. It is not coming from the evaporator or heater core as it only leaks while sitting during rain storms and washing.
I removed the interior panels from the back glass to the lower kick panel and did some tests with a water hose.
I noticed water leaking from around the cabin air vents in the rear, the speaker wire grommet going into the kick panel/body, and where the door is welded or attached to the kick panel/body.
I replaced the cabin vents and placed electricians putty around the edge and this fixed the leaks around the vents.
Electricians putty did not work well for the speaker wire grommet, so I now used black RTV around the grommet and around the door mounts on the kick panel/body as much as I could reach w/o removing the door (i.e. 3/4 of the mount, could not get the edge facing the engine).
Well, we just had another rain storm this past week and once again there is still water leaking on the passenger side only. It fills up the passenger side kick panel and then flows down to the passenger side floor. I keep the interior panels off on the passenger side so I can soak up the water after a storm.
Before I proceed with removing the front fender to see how else water can leak into the passenger side kick panel, I figured I would post on here for more ideas.
Any thoughts on how/where the water is getting into the passenger side kick panel?
Thanks.
1995 Lumina LS Sedan 3.1L - 215K mi - Daily Driver
2002 Accord EX Sedan V-6 - 209K mi - Wife's Daily Driver
2000 Silverado LS RCSB 5.3L - 168K mi
Old 03-29-2012, 02:32 PM
aleekat aleekat is offline
Re: Water leaking into cab - passenger side front only
Since you have your panels off. Get some cheap baby powder/talc. Shake it on the vertical surfaces. Then I would run the garden hose, starting at the lowest point or where you suspect the leak is coming from. The water will leave a "snail trail" in the talc. It will help you narrow down how it is getting in. Is this by chance a extended cab? I tried to see pics of the silverado. My Ram has a piece of rubber molding on the roof above the rear passenger windows. Under that rubber trim is a body weld. Thats where mine starting leaking, it would run along that weld, works it way down the back wall and enter the back area. Run down the edge until it got to the sill and move up front. I had this leak on both sides and took me forever to find it the first time. Got some exterior silicon house chalk, pried the molding up and sealed the entire weld then put the rubber trim back down in a bed of the silicon.Good luck
Water leaks into my passenger side floor board ap0c8 Grand Cherokee | Grand Cherokee SRT8 2 06-17-2009 04:06 PM
1999 Water leak on the passenger side phaderus Grand AM 1 01-02-2007 05:55 PM
Water leaking into passenger compartment LSC SS Galant 5 12-10-2005 08:55 AM
