Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 03-28-2012, 09:47 PM
yukon6inchlift's Avatar
yukon6inchlift yukon6inchlift is offline
e-150 with a dana 60?
my rear end started makin a funny noise so a friend and i took it apart. the clutch plates for the limited slip were trashed. tabs missing and a couple bent real bad.
every place i call to find a used one says they didnt put dana 60's in 1/2 tons. i'm sure this is a dana, tag on it says 9.75 ring gear. 5:33 on pinion. my service manual says its a dana 60. i have 5 lugs.
my questions are #1 is this a dana (will try to upload a pic)?
#2 since i cant seem to find one for a van (dana's on pickups seem to be narrower on the perch mounts) should i go with the common 8.8 ? seems like thats all that will fit
#3 is is possible somebody tried to put 5 lug axles in a 3/4 ton rear end? my friend said it looks like someone didnt set the rear up correctly
FS: 1970 B-Body Dana 60 for Numbers Matching Resto GSXMEN Parts for Sale 0 11-21-2007 08:25 PM
9.25" to dana 60 swap construct30 Ram Van 0 04-15-2007 12:21 PM
98 ram 2500 dana 60 seal problem hillboy Ram Pickup | Ram SRT10 2 04-18-2006 05:55 PM
DANA 60 3rd members geojoh Engineering/ Technical 0 01-21-2006 10:40 PM
dana 60 zboom86 Camaro Discussions 3 05-21-2004 12:09 AM
