Old 03-27-2012, 04:55 PM
guiwee's Avatar
guiwee guiwee is offline
removing paint from resin
hi guys .....i just got my hobby design novatech rossi 458transkit and have a couple questions??.....how do you remove paint from the resin pieces....in my rush to tryout my new airbrush i just cleaned the parts with soap and water..let dry..and painted alclad gloss blk...lo and behold i have fisheyes...i know what caused them but how to remove paint.....will lacquer thinner melt plastic or soften...my first time working with resin also..knew i shoulda primed...lol....any tips or help would be appreciated!!!!
Old 03-27-2012, 06:45 PM
RonCla's Avatar
RonCla RonCla is offline
Re: removing paint from resin
I removed the paint off a Fisher resin body once by just wiping it with off with a cloth soaked in lacquer thinners. It had no effect on the resin at all.
On another occasion I soaked some Replicas & Miniatures resin parts in 99% Isopropyl alcohol over night and the parts were like soft rubber the next day.
What ever you use proceed with caution and test a small area first by soaking a Q tip in your solvent of choice and just rubbing a small area to see what effect it will have.
Old 03-28-2012, 09:38 AM
andybmw7272 andybmw7272 is offline
I think the real questions before anything is what kind of paint are you stripping?
Old 03-28-2012, 12:02 PM
subway80 subway80 is offline
I have used EZ Off oven cleaner and had no problems.
Stew
Old 03-28-2012, 01:21 PM
360spider's Avatar
Lacquer thinner - just soak a rag and wipe it off.
DON'T use brake fluid or Castrol super clean - it will ruin the resin.
ItalianHorses.net
Old 03-29-2012, 12:44 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
I use Pine-Sol to safely strip paint from resins and plastics . . .
Submerge the entire part, wait for the coating to wrinkle up and it will practically fall off by itself.
Any remaining bits in body lines and such can be flicked off with a toothpick.
Even works on prepainted diecast and used it as a safe alternative to stripping Pocher Ferrari kits.
Also, while it does work with Tamiya paints. It turns the coating into a gooey mess. Use disposable brushes and whatnot . . . cuz they're going to be junk and hard as rock when they dry. . .
Chuck
Stripping paint from resin 250 Testa Rossa Car Modeling 3 02-16-2011 05:17 AM
Removing paint from resin. willimo Car Modeling 6 02-10-2005 09:26 PM
Remove paint from plastic and vinyl T!mmy Car Audio 11 02-24-2004 05:19 PM
Removing paint from windshield TougeMonkey Car Modeling 4 12-18-2002 06:37 PM
