Old 03-27-2012, 11:40 AM
NHRA's Avatar
NHRA NHRA is offline
94 blazer ac blower fan control
94 blazer ac fan will work on low and med but not high replaced resistor under hood but still no high speed fan?...........thanks
Old 03-27-2012, 11:42 AM
NHRA's Avatar
Re: 94 blazer ac blower fan control
im thinking there may be a high speed fuse? somewhere anyone know for sure..........cheers
Old 03-27-2012, 12:15 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
High speed also used a high blower relay, that may be your problem. Or could be the switch itself, or a wiring issue between the two.
The Following User Says Thank You to gmtech1 For This Useful Post:
NHRA (03-27-2012)
Old 03-27-2012, 08:11 PM
j cAT j cAT is offline
check all fuses with a voltmeter power on.
since you have the lower speeds the only component that is changed when you go to max blower would be the high speed relay.
first find the high speed relay . then with the switch set to max blower speed see if you get voltage and ground at the relay coil #85/86 pins.
if so then check for voltage at #87/30 . if the voltage is not on both these pins of the relay then the wire or fuse /circuit is open that supplies power to the relay switching contacts.
as mentioned it is possible the switch at the max blower speed position is bad. I doubt it.
If the fuse is blown this may mean the blower motor is in need of replacement. remove blower and see if it rotates freely . bushings not worn or debris interfering with rotation. also wires shorted . fuse should be over 20 amps. I think !
The Following User Says Thank You to j cAT For This Useful Post:
NHRA (03-27-2012)
Old 03-28-2012, 06:49 AM
NHRA's Avatar
ok on the relay think there is like 8 pins one has a burnt mark the relay is for the blower motor i think about a 1 1/2 sq im going to relace that today...thanks everyone.....
yeah it #87 thats burnt...cant find a new one yet...............
Old 04-02-2012, 07:04 AM
tg5398 tg5398 is offline
Where did you find the relay?
Old 04-02-2012, 07:30 AM
NHRA's Avatar
got it at autozone, had to order it took 1 day and worked like a charm<<<<<<<
Old 04-02-2012, 07:53 AM
Sorry. I meant where on the truck did you find it?
Old 04-02-2012, 08:19 AM
NHRA's Avatar
on mine its 94 and under the hood and its on the middle of the fire wall on a bracket one bolt holds it on
the relay has 5 wires and its about 2 1/2 in tall and like 1 in thick
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
No air flow from vents, blower fan running ts1653 Windstar 5 07-19-2014 01:02 PM
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
Proper fuse for Blower Motor Control Module and Blower Fan Clay_Bee Park Avenue 4 10-15-2004 10:44 PM
Blower Motor Fan Control ZR800 C/K 0 02-18-2004 08:02 AM
