Old 03-26-2012, 07:50 PM
Dew70 Dew70 is offline
89 escort automatic
Hi all..I am new to the site and am looking for some advise. I have an 89 escort with an automatic and when it is cold, it doesn't want to shift through the gears. After you warm it up, everything works great. I have changed the filter but didn't seem to help. Any advise will be greatly appreciated..thank you...dew70
Old 03-27-2012, 08:17 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 89 escort automatic
Welcome to AF!!
It sounds like you could have some sticking valve body components and solenoids. Add a can of Seafoam transmission additive to the transmission and see if that helps. It if is gummed up that will remove the gum from the valve body and should help it to shift better.
Old 03-27-2012, 06:10 PM
Thanks for the advice!! Will try that and see what happens!!
Old 03-31-2012, 11:17 PM
mmerlinn mmerlinn is offline
As noted, you may have sticking valves in the valve body. However, there are NO solenoids in your transmission, so there is no way that you have any sticking solenoids.
Old 04-01-2012, 07:32 AM
Pontiac Guy
Sorry for the solenoid information. I am more in tune to the newer transmissions that are electronically controlled.
