A Bird Without Wings
I own a 1989 firebird formula with an L98 motor in it.( I was told it was a Corvette Motor) Tonight I went up against a good friend of mine in a race. He beat me but, thats not the bad part he did it in a 2000 Ford mustang. It gets worse he has a v-6 motor. I need to know how to race an automatic and how I can get the most power out of my engine when I do race. Please, any comments or suggestions to help.
well, its old so these are some things ya need to do when u purchase a thirdgen
fuel filter cap, rotor, wires, plugs air filters adjust TPS sensor clean and reset IAT sensor good oil and filter tranny service and possible rebuild with better parts tranny detent cable adjustment timing catalytic converter condition rearend service theres also lots of free mods for these cars to: throttle body coolant bypass weight reduction port the EGR cast wall in the plenum ac delete emissions delete cold air intake bump up the timing things you should do: get an exhaust and high flo cats as well as headers (the stock parts are highly restrictive) a cold air intake, or a K&N cone on the end of the stock dual manual control fans 160 or 180 thermostat
89 ROC - 305 TPI 5 SPD - 13.9 @ 97.08
Thanks I will definitely look into that. Do you know if I should use first second and drive gears when I race.
drive, check what ur wide open shifts are at in drive, should be at like 5000-5200 dependign on ur rear gears, any higher then that and ur loosin time due to bein otuta the power band
