Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-25-2012, 07:33 PM
ngsiufung ngsiufung is offline
Refill Wiper blade
Hi there,
I want to change my 2010 Camry wiper blade, just the rubber to save some money. Do anyone of you know the part no. of driver side and passenger side and web site I can try? Thanks.
Old 03-25-2012, 07:50 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Refill Wiper blade
Buy them from a Toyota dealer parts department. They are really cheap and they will work correctly. If you don't buy Toyota blades, you are not getting just the blades. You will have to buy the entire support also.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-25-2012, 10:19 PM
somick's Avatar
somick somick is offline
I bought mine at the dealer on sale for 10 dollars. Not cheap! You can buy the entire assembly for half the price. I do not know why but the ones I have are of an exceptional value. I have been using them for more than three years with absolutely no problems.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-25-2012, 11:07 PM
ricebike ricebike is offline
all i know from a website if you still have the original frame wipers:
24" narrow refill driver side
20" narrow refill passenger side
sometimes they're wrong
so
measure your current wiper blades in millimeters
length and width
goto local advance auto parts store
or
oreily's if you're out west...
Trico makes narrow style "twin-rail" refills only (you reuse the steel metal ribs or spines for exact fit)
(at least on amazon.com)
sometimes cheaper than OEM
still made of natural rubber is the only con, so it will also dry-rot in time
if i had the dimensions, i'd probably upgrade to a silicone refill (if they still make them in the aftermarket)
went on autozone and advance auto parts...
autozone has cheapo wiper refils using a plastic spine (they suck)
advance auto parts only list on the local site some sort of cut-to-fit application for the trico models ~$7 each
8mm square claw blades
or
7mm trapezoidal claw blades
Caravan Wiper Blade Tip jeff618 Caravan | Voyager 0 10-18-2010 04:15 PM
Equinox windshield wiper blades Ruley73 Equinox 0 03-14-2010 06:57 AM
How to change wiper blade? serge_saati Cutlass Series 3 01-03-2010 12:08 PM
refills for OEM wiper blades thumpin455 Aurora 2 11-22-2003 09:24 AM
