Old 03-20-2012, 03:20 PM
jayjp200 jayjp200 is offline
98 Windstar 3.8L - Upper intake hose question
Hello,
On my 98 Windstar 3.8L the Upper intake air hose to brake booster feels to have pressure builtup inside and expands as a balloon somewhat.
Is it suppose to be under pressure or Vaccuum?
Please reply.
Thanks.
Jay
Old 03-20-2012, 03:59 PM
94LebConv3La604 94LebConv3La604 is offline
Re: 98 Windstar 3.8L - Upper intake hose question
Mine acts the same when I manually tweak open the throttle plate. Slightly bulges at the Intake end. I'm not saying that it is supposed to as I'm currently trying to figure out an intermittent misfire situation and as far as I know it is supposed to be under vacuum.
*edit*
I encourage anybody with a 98 3.8L engine that is running well to test this for us. Pretty please?
Old 03-21-2012, 12:26 PM
12Ounce 12Ounce is offline
Well, we all know the vacuum is (normally) the highest when the throttle is closed. On the chance that someone has changed out the hoses ... possibly to a thinner wall hose, that shows pressure differences more than the OEM ... or that the hoses are hooked to the wrong spot, here's a primer....'99 3.8:
There are three vacuum ports on the "backside" (engine RH) into the intake manifold spacer (between plastic upper and metal lower).
1) Toward the engine front, there is a port for feeding the vacuum controls inside cabin and elsewhere.
2) In the center, there is the port that feeds the vacuum booster.
3) At the rear, (near tranny) is the port that feeds vacuum regulator and control for EGR system.
Hopes this helps, but I've never yet noticed if the hoses flex or not.
Old 03-21-2012, 01:02 PM
Mine is only slightly visibly bulging. When I have my other hand on the hose I can definitely feel it expand slightly when I tweak the throttle plate.
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
98 3.8L upper intake designed to fail j cAT Monte Carlo 20 03-19-2010 10:19 AM
98 windstar 3.8l upper intake izaquad Windstar 3 04-05-2008 01:03 PM
Gm 3800 3.8l Upper Intake And Plenum 3.8 Repair Kit cmotown1 Park Avenue 2 11-15-2006 02:16 PM
