Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-18-2012, 06:24 PM
phileepo phileepo is offline
Angry Power Steering Hose
Just replaced my power steering pump on my 00 montana POS. Then I see leaking further back. After taking it all apart (again) I have determined that the High Pressure hose is leaking, rather bad, about half way down the rubber part. So my question is how in the blue blazes does one remove the line from the rack without having a lift or rubber arms? Is it accessible easier if the driver side tire is removed? Any help appreciated. I really don't want to pay someone to work on this van, it has 240,000 miles by the grace of God and my tender loving care over the last ten years.
Old 03-18-2012, 06:27 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Power Steering Hose
Removing the tire may give you some more room, but you're in for a fight not being able to get the car in the air.
Old 03-18-2012, 06:29 PM
Hey GM tech guy, with the thing in the air, how hard is this job? I mean it is like impossible laying on your back as far as I can tell.
Old 03-19-2012, 07:45 AM
gmtech1's Avatar
It can be tough still. You need to seperate the steering shaft from the steering gear, then lower the rear of the engine cradle. This will give you the room you need to get to the hose. Make sure everything is undone up top before raising the van and dropping the cradle down.
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
