Go Back   Automotive Forums Car Chat > BMW > X5
Old 03-17-2012, 04:52 PM
malibumlk malibumlk is offline
Did I fry my ECU??!!
'01 X3.0i auto;
This morning I was trying ton confioirm Peak code 7b (Thermostat map control) which as I understand, is related too the heating element of the main Thermostat (2 prong connector on top, just behind the top of the fan blade).
To check that I was getting power to the plug/heater element, I connected my volt meter to the 2 prongs in the plug/harness side and turned the key on while watching. The meter bleeped a bit but nothing, so I dicided to start the engine and see if that would bring the power up. No start.
It turns over but wouldn't start. Replugged the connetor - same. Checked all related fuses - OK. Disconnected the battery for an hour - same.
Any help on something like this??
THANKS IN ADVANCE!!
Worried
Old 03-17-2012, 06:54 PM
FishFind FishFind is offline
One Hot Shot
Re: Did I fry my ECU??!!
I don't know much about your car but hope someone will help you soon.
JDM ecu Vs. OEM ecu blisk323 '88 - '91 Civic | CRX | Wagon | Shuttlee 14 09-08-2006 03:38 AM
vtec ecu or non vtec ecu CIVICLX93 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 09-29-2005 09:39 PM
Clearing the CEL....? Why did the ECU not reset? The1NamedMarc Cutlass Series 3 03-29-2005 10:17 PM
anybody know the difference between P72 ECU V.S P73 ECU gotrice007 Integra 5 11-27-2004 04:14 PM
I Did The ECU check Finally.... animal66 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-25-2004 06:12 PM
