Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 03-17-2012, 03:33 PM
Tapout417 Tapout417 is offline
Whining noise during acceleration
Ok I have a 2001 Denali AWD 6.0, and when I accelerate it makes a whining noise as if it were low on power steering fluid, well I just replaced the power steering pump today and the ring and pinion with bearings about 1000 miles ago. Still whining, the shop today said it could be transferred case but I doubt that because I had it inspected when the ring and pinion was replaced. Any info is greatly aprreciated
Old 03-17-2012, 06:36 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Whining noise during acceleration
Is the noise RPM related or vehicle speed related. Drive the vehicle to speed that whine starts, shift into neutral and rev the eng, if the noise changes then it's not in the drive line.
Old 03-17-2012, 09:03 PM
I just took it out, it is defiantly RPM related. I can rev it in my garage and hear it, so I took it for a drive the noise starts right when I accelerate, so I shifted into neutral and reved it up and the whine got alot louder
Old 03-17-2012, 10:56 PM
FishFind FishFind is offline
One Hot Shot
Take off your belt and run it in your garage again and see if it stops. If so you will have to see what pully is doing it.
Old 03-19-2012, 09:56 AM
Ok I'll have to try that this weekend I'm outta town till then, how will I be able to identify the pulley?
Old 03-19-2012, 12:23 PM
gmtech1's Avatar
The easiest way I found is to use a stethascope. You can get one from a parts store. REmove the end on the tube and just use the tube. Move the tube from pully to pully until you find the noisy one.
Old 03-19-2012, 04:26 PM
Gmtech1 is that with the belt off or is it possible to do it with the belt on?
Old 03-19-2012, 05:34 PM
gmtech1's Avatar
With the belt on, run eng till you hear the noise, then move the hose around each pulley, and componants like the alternator and p/s pump and water pump and see where the noise is loudest.
Old 03-19-2012, 06:21 PM
Ok sounds good I'll give it a shot tomorrow, thanks
Old 03-22-2012, 05:27 PM
Ok tried the stethascope and no luck, I couldn't pin point a significant noise that was different from any where else, any other suggestions?
Old 03-22-2012, 06:04 PM
gmtech1's Avatar
FishFind suggested to remove the belt and see if the noise was still there, is it?
Old 03-22-2012, 08:11 PM
That hasn't been a option to try im currently outta town with the truck but I'll have it home this weekend and give that a try, just didn't have the tools to remove the belt in the hotel parking lot
Old 04-16-2012, 04:40 PM
bcopeland bcopeland is offline
Is it coming from under the hood or from the rear of the vehicle? I had similar problems on my 2001 and it was the rear expansion value.
Old 04-16-2012, 07:31 PM
Its coming from under the hood, I just had another power steering pump put on and completely flushed bc that what the shop said, and it still whining, 3rd new pump since January and no fix, noise driving me crazy and not one mechanic can figure it out, I've told them unless the guarantee the noise will be gone once they replace something don't work on, and so no one will
Old 06-24-2014, 09:27 PM
pthomas8 pthomas8 is offline
I have a 2005 Denali making the same whining noise but when I tried the acceleration and neutral test the sound went away. I believe this may eliminate the drive train as the source. However, what does this reduce my choices to?
Noise during acceleration-99 prizm stearnski Prism 7 02-22-2008 03:22 PM
Dragging noise during acceleration - 1985 Toyota Cressida sdbear Cressida 0 11-08-2006 07:40 PM
Rattling/knoking Noise During Acceleration Jet707 Jetta/Vento/Bora 5 12-15-2004 12:29 PM
Wierd noise during acceleration sugarmagnolia07 Cutlass Series 0 10-21-2004 09:12 PM
Noise during acceleration TMalone 323/Protegé/Familia/Etude/Allegro 2 03-06-2004 02:57 AM
