Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 03-17-2012, 01:36 PM
PRose PRose is offline
Moly Rings for a Chevy 265?
Hi. I am building a 55 chevy with a 265 bored .060
with JE forged pistons. Does anyone know where I
can find Moly Rings for a .060 over 265? JE wants
a part # for the rings before they make the pistons
as it is a custom order.
Thanks in advance.
PRose
Old 03-18-2012, 08:53 AM
maxwedge maxwedge is offline
A990 racer
Re: Moly Rings for a Chevy 265?
Try Hastings.
Old 03-20-2012, 12:41 PM
MrPbody MrPbody is offline
AF -Advisor
Speed Pro (Federal Mogul/Sealed Power) lists part no.
R-9519-65
This should be just what the JE engineer wants to "see". This is a plasma-moly top ring, ductile iron second and "normal" tension oil ring. The compression rings are "file fit", thus the "65" (.065" oversize) on the part number. 1/16, 1/16, 3/16
It also occurs to me, this is the same bore size as a 305, so a set of "stock" moly 305s (plus 60, of course) would work fine for a "driver". Use the "early" 305 stuff (pre-88) as the later parts are "metric". A more "conventional" 5/64, 5/64, 3/16 "pack"...
Jim
Old 05-13-2012, 12:02 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Jim
Sorry Jim, no cigar for you. The 265 was 3.750" bore x 3.000" stroke. Taking a +0.060" cut on the bore would make the motor 3.810" x 3.000". The 305 was 3.736" bore x 3.480" stroke and a +0.060" bore increase would put the 305 bore at 3.796". Close, but no cigar.
Richard
P.S. Using a 265 block and having custom pistons made for it is insane in my opinion. 350 blocks are available free most anywhere you ask, so why would you spend the bucks for custom pistons when you can put a set of "over the counter" pistons in a 350 block for less than a hundred bucks? Put 265 decals on the valve covers and lie about it.
Chevy 265 performance V8lover General Discussion 4 05-13-2012 04:34 PM
1993 Chevy Lumina O-rings for Fuel Pressure Regulator Dezik Lumina 3 12-04-2010 05:53 PM
o-Rings for 1993 cpi spider rbuck Blazer 13 12-16-2005 07:36 PM
A6 Pistons and Rings for sale... New In Box ZedEx Classifieds 0 02-22-2005 02:17 PM
O-ring for coolant return tube lizzyfly Grand Cherokee | Grand Cherokee SRT8 0 10-23-2003 11:22 AM
