Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 03-16-2012, 10:03 PM
bpopilek bpopilek is offline
Question 2004 Leaking Coolant
Ok, well I thought that my problem was fixed, but apparently I was wrong. I recently was having trouble with no heat in my truck, which I found was caused by low coolant levels. I replaced a bad water pump, gaskets, and thermostat and then thought that I was good to go. Wrong! I have noticed over the past couple of weeks that my coolant level continues to drop. I have checked my hoses and the water pump gaskets, but I cannot find where it is going. I don't see any drips or any puddles on the driveway. I do detect the smell of burning coolant when the engine gets hot. I have checked my oil to see if it was showing up there because of a bad head gasket, but it looks normal. Does anyone else have any thoughts? Thanks for reading!
Old 04-16-2012, 04:44 PM
bcopeland bcopeland is offline
Re: 2004 Leaking Coolant
Could be a pin hole leak in a hose. That is most likely the problem. Could be a bad radiator. Get a pressure check done on the cooling system at Pep Boys or borrow the kit from Autozone.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2004 truck 4.8liter cracked head slowly leaking coolant FantasticChadwick Silverado 7 10-11-2009 05:03 PM
Small Coolant Leak/Burnt Coolant Smell Through Heater??? Please HELP ASAP! NebulaD Sable 6 04-08-2007 09:50 AM
2004 R/T Stratus leaking coolant hank_P Stratus 3 12-10-2003 09:46 PM
