Old 03-14-2012, 08:40 PM
papher51 papher51 is offline
delco 6 disc wiring
I have a delco 6 disk am-fm factory radio 2003 silverado. The wiring connector is as follows. B1-Rd w Wh stripe-- B2 thru B8 n/a --B9-tan-- B10-Wh-- B11-Gr --B12-Orange, but a little different from the other Oranges almost a peach. A1-Or -- A2 thru A7- n/a -- A8-lite Bl -- A9-Bl -- A10-Or A11-tan -- A12-Bk. The red with white stripe is always hot. and of of course black is ground. I'm looking for the ing. wire that goes off with the power. P.S. the original radio was a delco am fm, no cd or cass.
thanks for any help tom
Old 03-14-2012, 09:23 PM
Re: delco 6 disc wiring
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
I found what I need, but the orange ass. wire is never hot. I need it to be hot when ing. is on.
Old 03-16-2012, 06:58 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like a blown fuse, check the fuses under the dash AND under the hood
Old 05-11-2012, 10:11 PM
daffodil1003 daffodil1003 is offline
Thanks you for the post.
The Following User Says Thank You to daffodil1003 For This Useful Post:
FishFind (05-11-2012)
Old 05-11-2012, 10:15 PM
FishFind FishFind is offline
One Hot Shot
PaulD how far are you from Rainsville?
Old 12-11-2012, 07:08 AM
Audio Guy
Rainsville, AL is about 1 - 1.5 hour drive
Old 05-13-2013, 08:16 AM
shahbaz shahbaz is offline
you should check your all fuses
Old 06-21-2013, 06:11 AM
idtest idtest is offline
I have a delco 6 disk am-fm factory radio 2003 silverado. The wiring connector is as follows. B1-Rd w Wh stripe-- B2 thru B8 n/a --B9-tan-- B10-Wh-- B11-Gr --B12-Orange, but a little different from the other Oranges almost a peach. A1-Or -- A2 thru A7- n/a -- A8-lite Bl -- A9-Bl -- A10-Or A11-tan -- A12-Bk. The red with white stripe is always hot. and of of course black is ground. I'm looking for the ing. wire that goes off with the power. P.S. the original radio was a delco am fm, no cd or cass. diesel test bench
Question about Orange Delco Shock Absorbers 99BlueBlazer Problem Diagnosis 3 08-31-2009 12:11 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 10:20 PM
wiring short in sterring colum? danielgast46 F Series 5 03-23-2009 07:35 PM
transmission wiring help please danielgast46 F Series 0 02-28-2009 09:33 AM
new AC Delco plug wires worsened problem atakordie LeSabre 13 04-05-2005 12:56 PM
