Old 06-02-2003, 07:53 PM
Jimboe29036 Jimboe29036 is offline
hangs in 5th gear
,93 Ford Escort hangs up in 5th gear--has full slave cylinder travel--no noises or grinding--mounts appear tight--Cannot find any linkage adjustment points[is there any ?] Any sugguestions as to problem ? No other gears involved but reverse is a little difficult sometimes [I know they;
're both on the same shaft ] Thanks for your imput.
Old 06-02-2003, 08:24 PM
pcv pcv is offline
Under the car, right below the shifter assembly, there is a bolt and nut that pivots front to back and side to side. I'd remove that bolt and nut, lubricate it really good. Wire brush it down if you have to. Every gear will be nice and smooth. Fight no more with the shifter. Good Luck.
NOTHING LIKE AN OLD CAR.
What is the best Top Gear/5TH Gear video? MITSU-EVO Car Videos 26 06-13-2004 07:54 PM
4th gear vs 5th gear 92 vx Nchakos '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 12-07-2003 01:53 AM
Top Gear or was it 5th Gear? Pringles Clio/Clio II/Clio III 2 09-14-2003 03:05 AM
Zonda Roadster on 5th Gear (Part of Top Gear Family) TheWretchedBeaver Zonda 1 06-10-2003 05:12 PM
switching out my S1 5th gear to an LS 5th gear... ? CRX586 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-17-2003 01:03 AM
