Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-12-2012, 03:44 PM
kgriggs75 kgriggs75 is offline
03 Ram 3.7 interesting problem
2003 ram 1500 2wd reg cab short bed. 80,000 miles .the truck came to me would not start and fuel was running from the tailpipe. the only codes p0320 and p0725 which means a crankshaft sensor problem. it also had a really bad vacuum leak in a line under the cab.
after replacing the sensor and the vacuum line and alowing the truck to sit over night, it fired right up ran for a while then died and would back fire and again fuel was running from the exhaust. when it dies the fuel pump does not shut off and the injectors and relay are clicking like crazy.
I tested the fuel pressure and sometime it will hold at 48 psi and some times it will start dropping with in a minute. I pulled the injector and leak tested the the redneck method. no leaks.
I can only think it must be an ecu issue? could a bad crank sensor cause this
2006 Chevy Uplander ls 3.5 128,000
1997 Buick Lesabre 3.8 and 135,000
1996 Chevrolet K1500 5.7 185,000
plus a 66 belair 65 gmc 70 c10 and a ford
2004 ram 1500 4.7 overdrive and idle issues mrwrench Ram Pickup | Ram SRT10 2 06-03-2010 11:22 AM
3.5L V-7 Compressor Removal and Reinstallation krivasauto Intrigue 2 05-13-2010 10:45 PM
96 Ram 1500 Electrical 7 Vac. Problems mrazekt2002 Ram Pickup | Ram SRT10 1 01-08-2009 02:12 AM
2005 Grand Am V6 3.4 Vs Dodge Ram 5.7 no_import2007 Grand AM 7 02-15-2007 06:47 PM
Next-Gen 4.7 or 3.7/3.9? Roscoe86 Dakota 6 06-06-2004 11:40 PM
Tags
3.7 , dodge , fuel , injection , stalling
