Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 03-12-2012, 02:31 PM
jnickleby jnickleby is offline
Door stuck open after lock stuck in the cold (lincoln mark viii '94)
I have yet to find anything of this nature searching through the online forums.
Here is my issue starting with how it is now stuck open:
On a day below freezing, I tried to unlock my car (driver side) but I couldn't. This had happened once before, so I climbed in the passenger side.
I then drove to work thinking it would warm up, though I found out otherwise.
I then tried to unlock it from the unlock button. It made the unlock noise, but the protruding unlock bar didn't move, so I attempted to pull it up.
I may have used too much force and I pulled the bar up so that it seemed as though it were unlocked (though it was still locked).
I then pushed it back down and tried the handle again. Nothing.
I remembered that if you pull the handle, it will unlock it sometimes too, so I pulled until it gave way (which took little force).
The handle then became loose and no longer functioned as before.
I ended up escaping the passenger side, but when I came back and started driving off, to my surprise my car door flung open and from that point has not been able to latch shut.
I apologize for the lengthy story, but I have taken the door panel off, sprayed it with lubricant, and attempted unscrewing the lock. My next bet is bringing it to a shop, but that is my last effort.
Any help would be great
Old 04-13-2012, 10:57 PM
spree spree is offline
Re: Door stuck open after lock stuck in the cold (lincoln mark viii '94)
This may not be much help but try disconnecting the unlock selenoid and closing the door, I had weird things happening when my solenoid went out. If it works replace solenoid or just leave it disconnected, I replaced mine....junk yard 2$
97 Mark VIII/Cobra motor ticking ymadmacks Mustang Talk 3 03-23-2010 01:08 PM
For Sale 97 Lincoln mark viii LSC in great condition Fredcao Cars/Parts for Sale/Exchange 0 09-09-2009 09:12 PM
What do you think about the Lincoln Mark VIII?? stwatson Mark VIII 20 08-14-2008 09:24 AM
Lincoln MArk VIII 1994 For Sale *USD$4000* BiggieRob Introductions 0 06-09-2004 10:25 PM
Tags
door , lincoln , mark , stuck , viii
