Old 03-11-2012, 01:01 PM
1996ctnc 1996ctnc is offline
Unhappy Help my Van won't start!
I just repaired and replaced the transmission a month ago. It is a 96' Chrysler town & country 3.8l /604 trans. the overdrive hub in the trans snapped in two "mechanical failure". Took it out and the repair shop and they did a thorough inspection said the rest of the trans. was fine other than the overdrive hub, replaced the broken parts with new and upgraded parts. It has been running fine up until yesterday starting all the time but now nothing. Cranks over strong I haven't checked for spark yet. It smells like it is flooding. Could it be the Crank positioning sensor? since it mounts in the trans bellhousing could it have been too close and rubbed or broke the end so it doesn't read properly? does it need a shim? after I put it back in it had a rubbing/ tinging noise that it didn't have before. I don't have money to go out and get another rig need to fix what I have going crazy!
Old 03-11-2012, 02:15 PM
jamesslcx jamesslcx is offline
Re: Help my Van won't start!
1996ctnc, could be Crankshaft position sensor. You really need to check for spark and do a little detective work before a real diagnosis though. Sorry about your troubles.
The Following User Says Thank You to jamesslcx For This Useful Post:
1996ctnc (03-11-2012)
Old 03-11-2012, 03:08 PM
I jumped the gun... duh! It was an easy fix. I found out that the fuel line had popped off under the car. I replaced the fuel filter last summer and must not have pushed the lines on all the way. That was the "flooding" smell. Checked all the fuel lines made sure they were all properly pushed on and problem SOLVED. I should have done more investigatinbg before I cried for help. Thanks for the reply.
Old 03-11-2012, 06:43 PM
1996, sounds like something I would do! Glad you fixed it.
Help, van won't start ! turbohounds Venture 0 01-10-2009 11:53 AM
1992 Asto van won't start...HELP Gerard822 M Bodies 5 03-23-2008 05:07 PM
Van won't start Please Help THIBAULT2400 Lumina 3 12-30-2005 10:19 AM
HELP! Van won't start annette26oh Lumina 7 12-03-2005 10:01 PM
Van won't start HELP!!! teege79 Venture 5 07-06-2005 01:23 PM
