Old 03-07-2012, 10:09 PM
FishFind FishFind is offline
One Hot Shot
P0446/P0507 blazer
I have a 1998 blazer 4x4
I had a issues with the car before and I had to turn the idle screw up until I fixed my problem. I now fixed my problem and I need to know what my idle rpm should be at.
After I fixed the original problem after about a day of driving I had a P0507 Idle speed High/Low. I turned the set screw down and lowered my rpm. After about 5min of driving the code went away on its own.
About 1 week later I am now getting the P0507 again and now it has a buddy. P0446 Evap System.
Questions what would my idle rpm be?
can the high rpm cause the EVAP code as well.
Old 03-07-2012, 10:26 PM
old_master's Avatar
Advisor/Moderator
Re: P0446/P0507 blazer
For the P0507, the procedure requires the use of a bi-directional scan tool.
The P0446 is a problem with the EVAP vent solenoid or its circuit. The high idle is not causing it.
You have to know how it works,
to figure out why it doesn't.
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
96 Blazer 4x4 2 door fuel pump marinesemperfi Problem Diagnosis 10 05-22-2009 10:56 PM
Performance Parts for 2002 Blazer ls Jandreau Problem Diagnosis 2 04-12-2009 04:28 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
