Old 03-07-2012, 10:04 PM
blk95lumina blk95lumina is offline
PAG Oil for H6 Compressor - 2000 Silv. 5.3L
Hello.
I am replacing the compressor on my 2000 Reg. cab Silverado 5.3L. Since it was built at the truck & bus plant in Indiana, it has the Delphi H6 compressor. Apparently there are 3 different compressors for the same exact truck for 2000 and other years.
What is the correct PAG oil for an H6 compressor?
The only thing I have been able to dig up is a universal PAG oil called PAG Blue. Maybe the recommended oil has changed over time or no one knows for sure what the factory put in the first place.
Thank you.
1995 Lumina LS Sedan 3.1L - 215K mi - Daily Driver
2002 Accord EX Sedan V-6 - 209K mi - Wife's Daily Driver
2000 Silverado LS RCSB 5.3L - 168K mi
Old 03-07-2012, 10:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: PAG Oil for H6 Compressor - 2000 Silv. 5.3L
As long as you use PAG oil, you will be ok.
Old 03-11-2012, 09:20 PM
j cAT j cAT is offline
Originally Posted by blk95lumina View Post
Hello.
Thank you.
a 2000 silverado takes pag 150 oil. there are different numbers like 50 100 etc... 150 is what was used in 2000.\
yes GM did change the pag number in later years.
MY experience is do not change this in mid stream or you can get problems. if it was oem built with pag 150 then you go with pag 150.
2000 Silv. Slow accleration HDIron Silverado 4 04-18-2011 03:36 PM
2000 5.3L Silverado brake system is weak but everything is new Silverado_Dude Silverado 1 06-14-2010 08:12 AM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 08:28 PM
2000 GMC 5.3L - using oil gkh7890 Sierra 3 12-08-2007 11:31 PM
2000 Silv/5.3L spark plug change advice needed rjirvine Silverado 4 06-09-2005 09:52 PM
