Old 06-02-2003, 07:59 PM
redvalkrie's Avatar
redvalkrie redvalkrie is offline
Send a message via Yahoo to redvalkrie
EGR System?
NO (PPM): Oxides of nitrogen (more commonly called NOx) are odorless gases that help form smog, and give smog its characteristic brown color. NO is produced when temperatures in the combustion chambers exceed 2500 degrees Fahrenheit. Excessive engine temperatures could be caused by a lean fuel mixture, by retarded timing, by carbon buildup inside the combustion chamber, or by a malfunctioning engine cooling system. The function of the EGR System is to reduce NO. Unhealthy levels of NO emissions result in a vehicle failing its Smog Check. NO is measured in parts per million (PPM).
This is what I failed in my smog check.
I have gon to Kragen auto parts to ask for EGR valves but they say that the 1988 Honda CRX Si does not have any EGR system.
Does any 1 know what these parts look like & are located in the engine bay, I would like to replace all components related to this EGR and NOX problem!
Thanx for any help given!
BTW: I have replaced the radiator the radiator cap and thermostat, car runs cool! (New coolant in her)
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!)
"Don't trip, skip, pinch your forehead"!
1988 CRX Si
2001 CBR 600F4i Silver & black FAST!
2004 Toyota Tundra (TRD)
2002 dodge grand caravan.
Old 06-02-2003, 10:25 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
you might just try running some fuel injector cleaner through... start with the simple cheap stuff and work your way up.
also, before you go get smog checked, make sure that your car is nice and warmed up so that the catalytic converter is working properly... they have to be hot before they are effective.
just want to cover the cheap stuff first so you don't pay more than you have to.
Old 06-02-2003, 10:26 PM
also, i think they are referring to something like OBD... i'm not sure though, but that sounds like what they are referring to.
Old 06-02-2003, 10:59 PM
91civicDXdude's Avatar
you're correct, a lot of hondas dont have EGR systems. check your timing, maybe give the engine a tune up, i dont have smog check here, so im not much help. sorry.
Old 06-03-2003, 03:29 AM
BullShifter's Avatar
Disconnect your PCV valve & plug the hose, then get tested. Make sure your car is hot before you go.
Old 06-07-2003, 04:20 PM
redvalkrie's Avatar
Unhappy Will DO!
Than-x guys will try all the sugestions you all gave me!
I picked up a Haynes manual and it said will in a diagram it shows an EGR Solenoide valve on the fuel injected CRX/HB/Sedans and a air jet and some other valves!
On another note I am thinking of getting a ZC how will that effect me getting smoged is there problems with passing smog with a ZC or will I just be not smoged!
1988 CRX Si
