Go Back   Automotive Forums Car Chat > Pontiac > Pontiac Classics
Old 03-06-2012, 03:42 PM
jokersall jokersall is offline
1976 grand lemans
i have a lemans with a 350. issue originally was lifter tick. its not oiling. backed the rockers off to see if that helped any. one started oiling but thats it. pressure gauge is showing 50psi. walked away from it that day and decided to try again later. again i have one oiling but now i hear metal on metal. maybe lifter and cam rubbing? opinions?
Old 03-06-2012, 04:09 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1976 grand lemans
Welcome to AF!!
It sounds like you have a blockage in the oiling system. If you have 50PSI on the gauge I would try another gauge just to confirm. Otherwise you will probably have to pull the engine apart and rebuild due to failure of the pump to lubricate the system. Hearing metal to metal is never a good sound.
Old 03-12-2012, 08:52 PM
Is there an oil port on the top end of the motor I can check pressure at?
Old 03-13-2012, 08:45 AM
MrPbody MrPbody is offline
AF -Advisor
Yes. By the distributor, there's a 3/8-NPT plug. It will have a 5/16" "square" drive if original. SnapOn has the correct socket. It won't "just unscrew" (DO NOT try it without following the instructions here, as it WILL "round out" and become a NIGHTMARE!). It's a tapered pipe plug and will need 'heat" to get it out. Heat the plug with a torch (propane or butane probably won't cut it, acetylene is called for) until it glows red (JUST the plug, not the block around it). Immediately hit it with some wax (candle, canning, etc.). It will then unscrew, usually fairly easily. This will give a clear view of oil pressure INSIDE the engine. You'll need an adapter to hook it up.
Jim
The Following User Says Thank You to MrPbody For This Useful Post:
jokersall (03-25-2012)
Brake issues on a Chevelle Malibu 1976 gagnon1s Chevelle 15 07-20-2011 12:27 PM
66 Pontiac Lemans issues xxGriffonxx LeMans 6 10-02-2010 08:15 AM
1989 Grand Marquis has no power a19thcfx Grand Marquis 2 03-29-2009 04:52 PM
2004 Grand Am bas gas mileage !! ChiLLX Grand AM 8 03-10-2009 08:30 PM
1976 Grand Prix Kansas Beer Grand Prix 1 07-21-2006 03:26 PM
