Old 03-05-2012, 03:24 PM
Jc1500 Jc1500 is offline
99 jimmy idle
I have a 99 jimmy replaced rotary button, cap, plugs, wires. The truck doesn't seem to run right. It idles fine but when in load it starts to sputter a bit. Going down the road between 2000 and 2500 rpms the tach jumps a bit. Now if I put it to the floor the truck runs out fine.
Old 03-08-2012, 05:30 PM
jamesslcx jamesslcx is offline
Re: 99 jimmy idle
Jc1500, Check engine light on? Have you changed the fuel filter? Run fuel system cleaner through it regularly?
Old 03-08-2012, 06:37 PM
Re: 99 jimmy idle
I just changed the fuel filter and put another egr valve on off another motor. I am about to try swapping the maf sensor then I guess its gonna be up to vaccum lines. The check engine light is on it is code 0452 and 0463. I am thinking I have a ground off somewhere from my recent install.
Old 03-08-2012, 08:35 PM
old_master's Avatar
Advisor/Moderator
Re: 99 jimmy idle
P0452 is indicating a problem in the fuel tank pressure sensor circuit.
P0463 is indicating a problem in the fuel level sensor circuit.
The ground for each sensor goes to a ground splice pack. One wire from the splice pack grounds to the frame, left rear corner, top side. Might be worth checking that first.
You have to know how it works,
to figure out why it doesn't.
92 Jimmy Dies When Idling rockavenger Problem Diagnosis 3 03-10-2009 09:52 AM
95 Jimmy Idle fast and Stalls Rudy3067 Jimmy 1 11-24-2004 02:04 AM
'89 Jimmy IDLE PROBLEMS bassman1 Jimmy 4 09-01-2004 02:50 AM
2000 GMC Jimmy idle clicking? Tupac2413 Jimmy 0 05-12-2004 09:04 PM
99 jimmy idles fast ksalyers Jimmy 4 03-16-2004 11:10 AM
