Old 03-05-2012, 11:10 AM
elliottdl elliottdl is offline
2001 Silverado knock sensor corroded.
While helping my brother replace the rear knock sensor on his 2001 5.3 Silverado we found that the cavity the knock sensor was in was almost full of coolant which corroded the sensor and plug. Where could this much coolant be coming from?
Old 03-05-2012, 12:58 PM
j cAT j cAT is offline
Re: 2001 Silverado knock sensor corroded.
the two piece intake manifold has a filler material that is supposed to keep out any corroding chemicals/water etc. the material GM used does not work. also [my first hand experience] rodents like to roast the acorns in there.
my guess is that the throttlebody gasket is leaking/hoses to it etc... the throttle body has coolant flowing thru it to heat up the air flowing to the engine. gaskets are a problem with the water pump and throttle body .
when closing up the intake upper/lower portion use silicone sealant between these two pieces so nothing can get in there.
replacing both ks would be good and making sure that the wiring /connectors have no corroding damage. the sensors require a good clean ground connection as well as output terminal
pressure test for leaks
2001 Yukon O2 Sensor Problems belbers1 Yukon 10 02-10-2010 10:23 AM
2001 Odyssey Knock Sensor froggiess Odyssey 3 10-14-2006 10:23 AM
2001 Tahoe knock sensor problems SteveSTahoe Tahoe 1 01-28-2006 06:15 PM
Knock sensor on 2002 Silverado? yolyvera C/K 15 12-06-2004 03:41 PM
