Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-04-2012, 12:02 PM
JimW1999 JimW1999 is offline
1999 Suburban brake line
I've read that a scan tool is required to bleed the ABS unit. A brake line has rusted out on the vehicle which I can replace, though not looking forward to it. The ABS unit is disabled by pulling the fuse. Do I still need to have a tech bleed the abs system? Of course I will bleed all four lines at the wheel cylinders and calipers.
JW
Old 03-04-2012, 02:37 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 1999 Suburban brake line
While it is recomended, it is not ALWAYS required to bleed the ABS unit (BPMV), replace the line as needed and do normal brake bleeding proceedure. If you cannot get a good pedal after normal bleeding, then you will need to have the BPMV bled with a scanner.
The Following User Says Thank You to gmtech1 For This Useful Post:
JimW1999 (03-04-2012)
Old 03-04-2012, 05:02 PM
j cAT j cAT is offline
JW
a specail scan tool would be required. if the leak is small replacing the line quickly with not much fluid leaking you should be good with just bleeding the lines.
when pumping the pedal do so slowly. this will not create air bubbles.
open bleed screws then push back the cal pistons to dump out any rusted debris first.
1999 suburban brake lights not working p diddy Suburban 8 08-06-2010 07:41 PM
1999 Suburban - Brakes GaOkie Suburban 1 01-25-2009 09:49 AM
1999 Silverado brake lines shot Wootmaniac Silverado 7 09-21-2006 10:19 PM
1999 suburban brakes superior Suburban 22 02-25-2005 04:00 PM
