Old 03-03-2012, 11:41 AM
thinmints thinmints is offline
96 xj multiple misfire issue
96 xj with 275000. 4.0 Over the last several months i have developed a problem of having multiple mis fires in the #6 cylinder, it started out when i was at a light the engine wouldn't idle smooth and the occasional misfire would occur but after time the mis fires would increase to the point of my check engine light would come on, the code reader said multiple mis fire in the # 6 cylinder. i replaced the spark plug and it fixed the problem but after a month or so the same issue happened again and again the check engine light came on and its the # 6 cylinder i replaced the plug again, and all was well but i have noticed that its starting to mis fire again i cant figure out why the #6 cylinder keeps developing this problem HELP!!!!
PS i have replaced the cap and rotor, plug wires are only a year old
Old 03-07-2012, 12:39 PM
72mino 72mino is offline
Re: 96 xj multiple misfire issue
How does the plug look? Is it oily? If so you could have oil leaking past a piston ring.
Dustin
Old 03-08-2012, 08:33 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
How many miles do you get out of a new plug before it starts missing?
Agree with 72mino on the oiled up plug.
Multiple misfire can also be caused by a bad Crankshaft Position Sensor; not bad enough to misfire with a new plug, but as the old one ages the cumulative electronic degradation gets to be enough to cause a misfire. Just guessing here.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-13-2012, 12:34 AM
i get about 2000 miles on it before i start to get any problems, when i pull the plug, to me it looks ok and is not oily, at first i thought the gap might have been off so i was very careful to gap it correctly this last time so we will see what happens, i'm going to replace all my plugs in the next few weeks and i may just replace the wires as well
Multiple cylinder misfire codes Pokee Windstar 6 05-04-2010 09:10 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
P0300 Multiple Misfire issues with 01 Suburban artmolina Suburban 1 01-17-2006 02:35 AM
97 chevy vortec 4.3 multiple misfires jcoffer C/K 2 07-03-2004 10:39 AM
multiple misfires (p0300) zdrepaul C/K 9 06-10-2004 08:54 AM
