Old 03-01-2012, 05:37 PM
98Z 98Z is offline
Send a message via Yahoo to 98Z
Fuel Neck Rubber Hose?
Does anyone know the dimensions of the rubber part of the fuel filler? I want to replace mine as I think it is the source of the fuel leak I have while filling the tank. I should have just replaced it while I had the tank out during the fuel pump replacement, but figured it would be ok. No one around here has any clue, so I was hoping to get the piece before tearing the truck apart again.
Thanks in advance.
Old 03-01-2012, 08:58 PM
j cAT j cAT is offline
Re: Fuel Neck Rubber Hose?
Thanks in advance.
the fuel filler tube is a hose in a hose. the inner smaller hose is for the fuel to go in to the tank. the outer larger hose is for the vapor to come out .
this is about 250.00 to replace. if you have a leak in this area it maybe the metal portion of the filler neck that holds the fuel cap.
it may be possible to use a metal mender epoxy to repair the hole at the weld area. the hoses are very durable unless thes have been cut .
Old 03-01-2012, 09:38 PM
98Z 98Z is offline
Actually, the one on my truck has a separate vapor line that is smaller outside of the main filler neck. The filler attaches to the bed side and there is a small section of rubber from that which connects to the tank.
Since I forgot to post this earlier, I'm working with a 1998 Silverado Z71.
Old 03-01-2012, 09:52 PM
something that old go to scrap yard. you may indeed have a problem finding new one .also the cost will be too much
if the metal portion has a hole the epoxy metal mender or marine tex works very good.
Old 03-02-2012, 10:19 AM
777stickman 777stickman is offline
Try this site.
http://www.lmctruck.com/index.htm
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-02-2012, 12:54 PM
777 stickman suggestion looks good if this is available http://www.lmctruck.com/icatalog/cd/full.aspx?Page=108
rubber hose from intake stephen_andrew Off-Topic 4 09-27-2004 08:49 PM
99 Camry I4, Rubber-hose on Canister? ty1 Camry/Camry Hybrid/Vista 4 08-01-2004 10:39 PM
