Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-28-2012, 05:53 PM
mishalah's Avatar
mishalah mishalah is offline
what is this groundstrap??
The one laying on top of the brake fluid reservoir, with the clothespin on the end. It has an "0" fitting at the end so it can be attached with a screw/bolt. The other end is attached to the firewall near the strap going to the engine block. I don't see any obvious place for it to attach but is is factory original and must go somewhere.
Hosted on Fotki
Hosted on Fotki
2004 Yukon XL Denali Luxo-barge for towing. 6.0L AWD grandpa hauler
2005 Suburban 1500LT/awd/tow/everything else...soccermom cruiser
2008 Nissan Versa HB...wife's skateboard
1997 Jaguar XK8 convertible...best road car ever
1966 Mustang GT convertible...fully restored concourse show car
Old 02-28-2012, 06:00 PM
j cAT j cAT is offline
Re: what is this groundstrap??
Hosted on Fotki
Hosted on Fotki
that is an OEM ground wire. I actually fixed my ground wire terminal that is on the firewall as the cable was not secured very good and the crimp had to be replaced.
tomorrow I'll see where the other end goes. could be the engine I bet.
Old 02-28-2012, 08:46 PM
ricebike ricebike is offline
mishalah,
a quick google image search points the other end of that ground strap to the
HOOD
weird, dunno why though
i can be wrong, though...
Old 02-28-2012, 08:57 PM
but, i'm thinking GMC did this for a reason: look at the following K1500 pickup...
and check out this pic on the upper right side; it's going up to da hood!
and this one going to the...
ooh! i found a perfect image... going to the HOOD
(loOol, beating a dead horse with pix!)
Old 02-28-2012, 09:16 PM
but wait, i got moar pix!
now the real question is why did GM put a ground strap from the firewall to the hood?
the one on the left is definitely connecting to the engine...
Old 02-28-2012, 11:44 PM
mishalah's Avatar
You're right. It goes to the hood. Ummmmmm...but why? I don't have a light attached to the hood, and there's no switch of any kind. And I couldn't find any kind of hole or place for a strap to attach.
A "grounded" hood. Okeee dokee. :P
Old 02-29-2012, 08:59 AM
your hood is supposed to have a light. the ground is for current to flow threw the wire not the hinges.
many years ago when we had ignition points I would install ground straps to the hood. this reduce am radio interference.. with the points long gone noise is no longer an issue ..
no hood light in the old days.
Old 02-29-2012, 12:11 PM
ah, sorta makes sense now...
my brother's 2004 chevy avalanche has no hood light now & has this dumb strap from the firewall to the hood that's why i flooded this thread with pix... because when I was doing an oil change and other preventative maintenance, this stuck on my head & wondered "WTF?!?!"
slightly offtopic: i noticed some ground-straps on nissans by the cat converter flange to the body... quest and on my 240sx... gotta get replacements for them since they are now frayed/ broken & were there for some reason as well
Old 02-29-2012, 01:05 PM
as A GUESS , THOSE MAY BE for the O2 sensors ..making sure the exhaust is properly grounded so no electrical noise will interfere with the signal.
what is this part? how do I fix this. PICTURES turbotec Caravan | Voyager 2 06-12-2008 02:10 PM
whats this on Eibach's site? JasIzBac Suspension 6 02-25-2002 10:16 PM
Not sure what this is, need Help imphatr Engineering/ Technical 5 02-19-2002 04:17 PM
Anyone know what this is? A380Driver General 9 12-10-2001 08:49 PM
whats this thing for? YellowMaranello Engineering/ Technical 4 09-29-2001 10:58 AM
