Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-02-2003, 07:07 PM
bears46d bears46d is offline
Question Programming key fob for 02 Buick Rendezvous
Anyone know how to program keyless remote for 02 Buick Rendezvous? Any help would be appreciated.
Old 06-02-2003, 07:26 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Moving to Buick Forum.
Welcome to AF bears46d
Here is the answer to your question, but it looks like you will
have to take it to the dealer since the Fobs have to be programmed
with a scan tool.
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs.
Press the START soft key on the scan tool.
Important
The scan tool must stay connected until all of the transmitters are programmed.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the locks will cycle in order to confirm the programming of that transmitter.
Repeat the previous step in order to program up to 4 transmitters.
Remove the scan tool.
Operate the transmitter functions in order to verify correct system operation.
Old 02-22-2004, 10:32 PM
pontiac-dude pontiac-dude is offline
Re: Programming key fob for 02 Buick Rendezvous
There's a manual method of programming keyless entry transmitters also. Make sure that you have all the transmitters you want to be able to use handy because the system will have to "learn" each one, even if they already worked before. If you have the memory seat/radio/mirror option you'll need to program the remote for 'driver 1' first, then 'driver 2', then up to 2 others. Here's how to do it:
1. Close the vehicle doors.
2. Turn OFF the ignition.
3. Remove the ignition key from the ignition lock cylinder.
4. Press and hold the driver side door lock switch to the unlock position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The body control module (BCM) will sound three beeps in order to verify the Program Mode has been activated.
9. Press the lock and unlock buttons on the keyless entry transmitter simultaneously for approximately 5 seconds . The BCM will sound two beeps in order to verify that the transmitter has been successfully programmed.
10. Perform the previous step to program up to four transmitters.
11. Remove the ignition key in order to exit the Program Mode.
12. Verify the proper operation of each transmitter.
Old 12-08-2004, 11:46 PM
rmarkw rmarkw is offline
Thumbs up
Thanks Pontiac-Dude, I followed the directions and was able to program remote. Saved a trip to dealer.
Old 06-18-2005, 09:05 PM
QHC QHC is offline
Send a message via AIM to QHC Send a message via Yahoo to QHC
Re: Re: Programming key fob for 02 Buick Rendezvous
Thanks again from me also. The manual programing instructions worked great on my 2002 CXL.
Quiller
Old 07-29-2005, 10:19 AM
82 meeno 82 meeno is offline
i have a question; i bought an additional remote to program; I followed your instruction and it de-programmed the original and programmed the new one. I was not able to program them both to work. What did i do wrong?
Old 08-02-2005, 01:32 PM
Re: Re: Re: Programming key fob for 02 Buick Rendezvous
I found out I only needed to repeat (step 10), to program additional remotes.
Old 08-02-2005, 02:19 PM
QHC QHC is offline
Re: Re: Re: Re: Programming key fob for 02 Buick Rendezvous
What you really mean is that you need to do what step 10 says, which is repeat step 9.
Q
Old 08-08-2005, 10:17 AM
Re: Re: Re: Re: Re: Programming key fob for 02 Buick Rendezvous
Q
Glad you knew what I meant!!!!
Old 01-12-2006, 08:44 PM
johnnyjack johnnyjack is offline
Will this same procedure work for an '04?
Old 01-14-2006, 03:19 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Yes, same for 04.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 02-04-2006, 04:10 PM
drac02 drac02 is offline
Will the following procedure also work for the 2005 Rendezvous?
Old 02-06-2006, 07:57 AM
Onblsht's Avatar
Authorized Vendor
It should if your remote has FCC: L2C0007T.
Old 07-13-2006, 03:20 PM
dug_e_j dug_e_j is offline
Thanks for the info, I used it too. Got a great deal on KeyFobs on E-Bay, two new ones for $40, shipping in. (Shipping to Canada).
Closed Thread
