Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-26-2012, 04:45 PM
HiLiter HiLiter is offline
Angry 2000 Plymouth Neon; No Spark
I have a 2000 plymouth neon that is becoming a headache. The car broke down as I was accelerating to approximately 35 mph. Engine would not turn over. Checked for spark. Had spark in 2 of the 4 plugs. Changed Ignition coil pack, cam-shaft sensor , crankshaft sensor, put new plugs in. Still would not start. Checked timing belt to see if it was spinning. Sure enough, belt was not spinning. Changed timing belt, water pump, new alternator belt, new serpentine belt. Timing is set perfectly on the mark.
Car fired right up after that. Would not idle and was running rough. Check engine light suddenly came on, never did during the whole breakdown process. Anyway, checked the TPS and found some cables loose, due to jacking the engine up and down. Car is idling on it's own at this point but still rough. Checked spark plug gaps. So reset all at .035 and put them back in. Car wont turn over at all. Checked for spark in #1 and #4 and now getting no spark at all.
All fuses have been checked. Fuel relay fuse was changed as well. Fuel is getting to the injectors, not sure what a pressure gauge would say but it seems to be getting enough fuel. Head gasket, valves, rings...etc have all been checked and are fine. Getting 100% compression as well.
I am at a loss. I don't know where to go from here. Any advice or suggestions are highly anticipated. Thanks in advance.
Old 02-26-2012, 07:41 PM
jamesslcx jamesslcx is offline
Re: 2000 Plymouth Neon; No Spark
HiLiter, do you have battery voltage leading up to the coil pack? If ignition system checks out problem could possibly be the PCM. Also make sure all your connections for cleanliness and tightness. Does this vehicle have an ASD relay?
Old 02-26-2012, 10:34 PM
I will look at the 2 things you suggested. The throttlebody, the cam shaft sensor and the crankshaft sensor have all been cleaned of debris. All hoses have been checked, all cables have been checked for cleanliness.
I will let you know if the PCM or the ASD was the problem. Thanks for your response!
Old 02-26-2012, 10:36 PM
Oh! I have battery voltage up to the coil pack. Thats why this is so confusing. Something is stopping the complete circuit.
Old 02-27-2012, 04:26 PM
HiLiter, let us know, I don't really have much knowledge of Neons and I like to learn about these problems.
Old 02-28-2012, 07:09 AM
Oldsmobile Doctor Oldsmobile Doctor is offline
A Neon has an interference engine. If the timing belt stops turning the cam it bends valves. Do a compression check to make sure. I also change the water pump and cam seal when I change a belt.
Old 04-25-2012, 04:33 PM
jacksonerica jacksonerica is offline
I have a 2000 plymouth neon and for the last couple of weeks the car would not start on some days and some days it wont. I took it to the shop and they said they couldnt find nothing wrong with it because it would start up every time he tried it. Then i took it to autozone and they ran a test on my battery and alternater and said it was fine. Also triple A said that it could be the starter while other people said the plug connected to the battery is loose but when i tightened it, the same problem occured again. Any suggestions?
Location of Fuel Filter 2000 Plymouth Roberto1953 Breeze 2 09-06-2007 06:07 PM
98 plymouth GrandVoyager spark plugs and Wires allboys6 Caravan | Voyager 5 05-16-2007 12:26 PM
2000 Plymouth voyager brake lights gcq4576 Caravan | Voyager 0 08-10-2006 07:00 PM
2000 Plymouth Neon stuck in park Arlene 2nd Gen 00-05 6 03-08-2005 03:52 PM
2000 plymouth breeze transmission pts Engineering/ Technical 0 08-06-2004 04:49 PM
