Old 02-25-2012, 09:09 PM
gk2010 gk2010 is offline
radio wont turn on
i installed a kenwood ddx-319 in my 2002 pontiac grand am. all wires are connected and i can tell power is going to the unit because the security light flashes. but nothing will come on the screen and nothing else will work. could someone give me some help with figuring out the issue..thanks
Old 02-25-2012, 11:17 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: radio wont turn on
there are 2 power wires that need to be connected, 1 to switched 12V and one to constant 12V. You may need to enter the security code the first time you power it up.
Old 02-26-2012, 12:14 AM
i connected those 2 wires and the screen wont come on for me to enter it
Old 02-26-2012, 07:25 PM
Audio Guy
check each of the wiresw to make sure they have the correct voltage, also where is the ground wire connected ? If you say the black wire on the harness, change it to a metal bolt behind the dash. If this is not a power/ground issue then it must be a defective unit.
98 A6 wont start, radio wont turn off TDWPgtp '96 - '04 1 02-15-2011 04:25 PM
Radio wont turn on display. It is now locked alc1974 Leganza 0 01-10-2010 12:50 PM
radio wont turn on after battery replacement Cavaturbo Prelude 1 12-08-2009 06:27 PM
Darn Bose Radio Wont Turn on! Jeff687687 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 09-23-2002 02:44 AM
