Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-25-2012, 05:09 PM
ejerome ejerome is offline
self test
I have a 2005 workshop manual and would like to run self test and diagnostics on my climate control datc but the procedure in the book is for a panel w/o heated seats. The buttons are different on the panel that includes heated and cooled seats.
Old 02-25-2012, 05:39 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: self test
Is your LS also a 2005? There is at least one post that has the details on how to run the self test for the LS with only heated seats versus heated and cooled seats. Try searching the forum. If you don't find it, or once you confirm the model year, post back. Also, please confirm if you are saying you have only heated seats, or if you have heated AND cooled seats.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
ejerome (02-25-2012)
Old 02-25-2012, 06:04 PM
Re: self test
Sorry I'm slow getting back ,Yes my car is a 2005 v-8 and it has heated and cooled seats the control buttons for the seats is included on the climate control panel in place of the floor and panel select buttons those buttons are combined into one the toggles between the different registers.
Old 02-25-2012, 08:39 PM
Re: self test
I found the procedure I needed it was posted to a problem in 2008 : to start self test on the control panel with heated and cooled seats with ignition on press off and defrost at the same time and then auto the codes are as listed in the book thanks for the help---- skip
Old 02-26-2012, 10:06 AM
shorod's Avatar
SHO No Mo
Re: self test
Glad you found the procedure. Did the DATC provide you with any codes?
-Rod
Old 02-26-2012, 11:21 PM
Re: self test
-Rod
yes the code was 2798 dccv short to ground drivers side, haven't had a chance to troubleshoot the wiring yet I'll keep you posted thanks for the help.
Old 02-27-2012, 09:19 AM
joegr joegr is offline
Re: self test
The short is usually in the DCCV itself.
The Following User Says Thank You to joegr For This Useful Post:
ejerome (02-29-2012)
Old 02-27-2012, 05:23 PM
Re: self test
yes I did the multimeter work and the datc is supplying voltage, got a new dccv on the way stay tuned
Old 02-28-2012, 07:39 PM
Re: self test
It works Thanks for your help---- skip
Old 02-28-2012, 09:01 PM
shorod's Avatar
SHO No Mo
Re: self test
Awesome, glad you got it fixed and thank you for following up on your thread!
-Rod
Question about DTC from self test cmax68 Focus | C Max 0 03-02-2006 11:53 AM
self test isa369 7 Series 1 10-09-2005 02:29 AM
Self test conn location Grassburr Explorer | Explorer Sport Trac 3 08-05-2005 06:28 PM
Self testing air stems can you buy them? JackBauer Yukon 1 01-06-2005 11:01 AM
ford self test? ohio420jb Taurus | Taurus Wagon 1 08-21-2004 01:07 PM
