Old 02-25-2012, 02:13 PM
Striger Striger is offline
1998 Windstar starts *only* in cold weather
I've got a 1998 Windstar 3.0 liter V6 that will start up only in *cold* weather, when the temperature is *below* about 25-30 degrees. When its warmer, all it does is crank and crank. Right now its not showing any codes, though before it was showing a P0171. When i cancelled that one out, it hasn't come back yet, even though its still doing this. Can't seem to find any postings anywhere on this issue! Thanks a bunch for any insights!
Old 02-25-2012, 02:29 PM
94LebConv3La604 94LebConv3La604 is offline
Re: 1998 Windstar starts *only* in cold weather
That code usually takes some time to come back but you may have some luck if you check the pending codes. Have you checked your IMRC bushings, actuators, and butterflies? Are you getting fuel to the cylinders?
Old 02-25-2012, 04:02 PM
tempfixit tempfixit is offline
Does your scanner read AMbient Temperature??? If so what does it read when it does not start???? What does the ECT read at cold cranking???
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
1998 sebring jxi convertible cold weather p/s noise L2bsing Sebring | Sebring Coupe | Convertible 0 02-18-2007 11:07 PM
99 windstar..won't start in cold weather tiredlazydog Windstar 5 02-06-2005 12:00 PM
Not starting in cold weather voovon Fiesta 1 01-27-2004 04:43 AM
94 2.2 Won't Start in cold weather johnhart Cavalier 4 12-16-2003 06:04 AM
